gbianchi
Everything posted by gbianchi
	I bring 10 12 14 17 19 22 sockets/ratchets, 1012141719 combo open/box, breaker bar with cheater pipes, little bfh, visegrips assorted sizes, pb blaster, gloves, a rag, saftey glasses, prying tool aka bfscrewdriver. Those knuckles can be a bear to remove, you need a 5/16 inch punch for axel pins, go threw the job in your head bring anything that comes to mind, plan then act.......G
Acceleration Stumbling Brat, Please Advise
gbianchi replied to dartron3030's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The epa junk I disconnected is, those 2 exhaust recycle deals on both sides of the engine, the pcv valve, the egr valve, that thing that has hoses running from it up by the drivers side strut top, any hose that connected to the carb that could be disconnected and not stall the engine, if it stalled when disconnected I reconnected and plugged, any thing disconnected was also plugged, sorry about not knowing the correct terms for these things. These engines will do just fine without all that B S, also I just did what some others here on the board have done, and now I just love my Brat again! Oh ya I should also add that I am running an EA82 distsy and coil, starts on 1 or 2 sparks everytime........Cheers G- 10 replies
- acceleration
 - brat
 - (and 5 more)
simular situation, same attempts to fix, finally replaced coil and disconnected most of epa crap, Brat is AOK now, a little cold blooded but worlds apart from where it was. Try the coil 1st........Cheers G- 10 replies
- acceleration
 - brat
 - (and 5 more)
[86 brat] shifting problems/clutch, take 2
gbianchi replied to apparition13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I 2nd the fork/throwoutbearing tip, I had the same prob on an 86, turned out the fork was cracked, replaced and good to go, its a small prob that requires alot of work to r/r. good luck...........G -
	Just read threw all this injector stuff as my wifes legwag 90 manual finally had an injector prob, knowing nothing about it, except they are kinda pricey went to the yard pulled the right side fuel rail with both injectors red tops off a 94 auto, installed the whole piece and it fired right up idles smooth as it should runs as it should, to soon for mileage numbers but no ECU swap and it looks as if its good to go, Subaru legos are plug and play............G oh ya 14bucks out the door!
	try swapping in a different coil, I had simular disty swapping going on and then solved the stumble with a coil, just 2cents, good luck...........G
New Problem on the Money Pit 85 BRAT
gbianchi replied to newgen85brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ok simular probs whit my 84 brat, tried all sorts of stuff no carb swap though, I am now running an ea82 ditsy that fixed the starting crap, then i got rid of most of the EPA crap that fixed the sputtering and stumbleing, now I just have a small issue in between cold and totaly warm, but so much better, now I can accually drive the beast and enjoy...............G -
1984 Brat Distributor, Cap, & Rotor Troubles
gbianchi replied to Harvester's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hello to all just wanted to update this post been driving the brat allot with this ea82 distributor and I have come to the conclusion that its not just wishful thinking! This brat starts/runs awesome, long ago when I purchased it I replaced the dist with a nippon unit from a 2wd wagon, started and ran O K but just seemed like something was off, then about 2yrs ago the starting got to be iffy at best, like it would fire after letting the key snap back from start to on, but only sometimes. New wires, new cap, new rotor, new plugs, readjusted air gap, every time things seemed to be better but for a short duration. I was gona throw down 125.00 for a reman at rockauto when a coworker got me this dist at pullnsave( he stashed it in the door he bought for a 72 jeep truck snicker snicker). Anyhow all is well and I'm loving my Huey again.......Cheers to all, G. 0
