Everything posted by subiemech85
tach installed, rev limit?
subiemech85 replied to Vicious-S's topic in Old Gen.: 80's GL/DL/XT/Loyales...
8,500 is max at this speed it really sounds good 5,500 is stock 3,000 is power -
to access the fan to remove the fan you must remove the shelf - cover assembly, the big duct, and the air box. it also helps if you remove the glovebox BTDT great time to clean the system
Ford probe STi ooooohhhhh yeah baby!!
subiemech85 replied to coloradosubarules's topic in Subaru Transplants
UGH!! :fingerinthroat: have you lost your mind? save all that money for something else that probe will be nuthin but troubles, FORD -
EA81 & EA82 alt compatability...
subiemech85 replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that will do it, so will the 2 wire connector not connected as always, check your grounds -
Cleaning alloys...how?
subiemech85 replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
carwash for the unfortunate the real way is 3,000+ psi 200*+ water with a good turbo nozzle and use trailer-brite for the soap on the injection line set on min. BTDT http://www.dcs1.com/del/chemguid.html -
OMG! Guess what I got to drive today...
subiemech85 replied to DrKrazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oh sure it'll go fast, but will it go S L O W?? :-P IF YOU CAN'T SEE THE PROBLEM, THEN what problem, I SEE NO PROBLEM -
82 BRAT wont move?
subiemech85 replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
a little bit is allowable, 1/8"? but if it moves a lot, you've got wrong disc or pp -
find a used one from a board member, ask me, I may have what you want, if you describe waht you need!!
with that kind of consumption, start by tightening the oil pan then replace the gaskets in the valve covers and oil pan if needed
usually the bushings closest to the rear of the transmission
as far as I know that is true search justy forum
it's more of the story behind it than the picture http://www.ultimatesubaru.org/forum/attachment.php?attachmentid=946 from the midwest 2 meet what a way to spend the day of senior prom
Even more photoshop fun.
it's a MilesFox trick, Duck Tape and spray paint the eyebrows is it a boy or girl? how does one tell???? McBrat makes good decals -
put beverage container of choice between the parking brake and the 4wd shifter
Help! Oilfilter seal problem.
subiemech85 replied to hellfire's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what filter are you using? what engine? is the filter housing damaged? try 2870A it's the fram # that works for purolator made Advance Auto and Quakerstate filters DO NOT USE FRAM http://www.scuderiaciriani.com/rx7/oil_filter_study/ -
tighten your lugnuts...
subiemech85 replied to monstaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use a torque wrench EVERY time I install a lugnut 75-100 ftlbs I once lost a nut on a H alloy, put a pug nut on, all was good -
Preferred gasoline for Subes?
subiemech85 replied to Phaedras's topic in Old Gen.: 80's GL/DL/XT/Loyales...
top teir gas from quicktrip I find that the empty lite doesn't come on as soon as with the "other" brand gas http://www.toptiergas.com/ -
82 BRAT wont move?
disconnect completely the clutch cable from the clutch release fork then see what happens -
looks like a snow king version of a ea82 the jsuty snow king is cool!
The old school Subarus in Austria
subiemech85 replied to Lukas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
stay away from the ecvt, unless you want to maintain the brushes the fi 5spd is a blast to drive -
cold weather problem...tranny/clutch?
subiemech85 replied to Del Gue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it's what happens when the gear lube is cold it acts to bind together the moving parts try running a thinner gear lube 75W80?? -
if it's above 32F, 0C, once should do, if it's colder, 2 or more see what works for you tap LIGHTLY, it does NOT take much
the no choke cold idle is about 700rpm the choke is a multi step system floor once or twice depending on temp to set choke start allow to run smooth, about 2,000 rpm gently tap gas pedal should be about 1,000 to 1,500 rpm after running smooth to about 2,000 rpm, accelerate to 3,000 rpm let go and it should idle 700-1,000 rpm works like a charm!
