Everything posted by subiemech85
I Hate Mice!!!! HELP!
subiemech85 replied to stephenw22's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I still keep pulling the insulation fuzz out that they made for me from the vents use OUST and JOHN DEERE MALODOR REMOVER, they work you can also use new car or courage little trees and don't forget the fresh shrubberies when they are in bloom, wow! -
Road Trip II: TrashWagon's RETURN
subiemech85 replied to MilesFox's topic in Meet n' Greet. Your USMB Welcome Center
turbo runs, they are here for the nite, heading out in the morning -
MilesFox, what's the progress? could drop off a car at my place if needed see you at the meet,, loaded with tools -
Midwest 2 Weather Forecast
subiemech85 replied to ShawnW's topic in Meet n' Greet. Your USMB Welcome Center
IT'S RAINING HERE, AND IN A HUGE RAIN BELT -
Midwest Meet: Special Offer: Custom Decals
subiemech85 replied to mcbrat's topic in Meet n' Greet. Your USMB Welcome Center
I'll order later when I decide and have REAL money, also will be an excuse to stop by your place! -
cv castle nut loosening
subiemech85 replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you never said anything about the big cotter pin that keeps the nut in place -
fastest/cheapest way to gain ground clearance
subiemech85 replied to The Scooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
tire pressure over inflate to raise deflate to lower works every time and is free -
glow plugs are a starting aid for diesels that do not use flame throwers, ether injection, etc. hitachi had anti dieseling solenoid for that purpose mmo works for cleaning, use it
Storage of a Wagon
subiemech85 replied to Rolloverbratboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sta-bil the gas and FILL the tank drain the fuel system, carb, lines disconnect battery, charge as needed use fogging oil, or sea foam to fog the engine oil all chrome and metal prone to rusting inflate tires to proper pressure place on jackstands and keep suspension in normal supported position silicone lube spray all weatherstripping lube chasis, thouroughly clean car and wax paint make sure doors are not locked good luck just have the car impounded, j/k!! -
http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b7a4f46.89471656/&FileType=Image&File=New%20Image.JPG
ea81 brake experts? couple of q's.
subiemech85 replied to Mr. Carb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bleed the mc, hh, then the brake lines -
Midwest Subaru Meet Parts swaps?
subiemech85 replied to MorganM's topic in Meet n' Greet. Your USMB Welcome Center
MilesFox: remember deebo on the right front 85 wagon ea82 fender, and splash shield if you have it for my car ShawnW: dash cover, $10 for anyone: emissions control system is available from my 85 wagon carb -
15.9 gal fuel tank yea right 86 turbo wagon 4wd
subiemech85 replied to Subi81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sure 16.2 to FULL completely ran out abot 500 feet from station, coasted in and filled up -
what you need to do is get ahold of every year fsm that has the dist advance tables and find one that you like, 85 had more than 10 tables!!!
Bypass EGR system? best way?
subiemech85 replied to smotocon1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
go all out and rempove the egr system and block it off, use a new gasket as the template, make the bolt holes accurate! you can also remove the asv system -
Squeaking with a heavy load
subiemech85 replied to subaru420's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I guess that when your car is similarily loaded in a month, you will discover that it was that wheel bearing, and you should have taken care of it a long time ago consider everything that rotates at wheel speed: dif, axles, brakes, bearings -
Replacing the 4WD light switch
subiemech85 replied to hilux_1990's topic in Old Gen.: 80's GL/DL/XT/Loyales...
see if you can have access when you remove the gear shift boot? my lo and or park brake used to be on whenever it wanted to ! -
Check out this subaru site - lots of info
subiemech85 replied to lagwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wow thanks!
