15
Everything posted by bratman18
EA82 front struts fit EA81 ?
bratman18 replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I drove it everyday on the road. I actually used adjustable ones, and cranked them up a little too. It didn't bother tire wear too bad, it was lifted a little over an inch I'd say at that time. I don't think the struts themselves will add much lift. I used the EA82 strut assembly with spring and all. No, I didn't add any reinforcement washers actually. I used flat washers with lock washers and cranked them down tight. Never had an issue, and it got tested too. -
Yes. I installed a set in the front of my brat a while back. I even drilled holes and used the ea82 strut tops. -
Did you plug the maf plug back in?
I'd like to try to make a side by side buggy.
bratman18 replied to utcoyotehunter's topic in Off Road
If its truly in good shape with no rust, it's a real shame to cut it up and make it a buggy. -
Nicole has quite the built up Leone, and has been looking for some pristine bumpers for a while, hence the offer.
You're not going to find new pug wheels in the right lug pattern. Used ones can be found, there's a source in New Hampshire actually, and he'll ship them too. That's where I got my steel wheels. Had them sandblasted for cheap and painted. Drilling the hubs doesn't weaken them to a point that you'll ever notice.
The front 02 is hooked up. And it was taken out of a running car, so it was good.
Yes I got it, sorry I haven't been in touch. Worked a week of storm work after a snow storm put out power to over 80,000 people. And I've had my kids every weekend. So time has been stretched. As soon as I get a chance, I'll be getting it installed and trying it! I'm praying it fixes it.
Take the nut off, and get a good angle with a big hammer, and give the control arm a good whack downwards.
That's the tie rod end. Thread the nut on upside down so you don't hurt the threads, and give it a couple whacks.
need tailgate hinges for 1986 BRAT
bratman18 replied to turfman454's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I might actually have a set of these. -
The Unofficial "How to Lift your Impreza" Thread
bratman18 replied to Kostamojen's topic in Off Road
98-08 foresters all have the same top hat spacing, and those are the ones that'll fit, but as said in this thread, you'll either have to drill a hole in the impreza body, or change the rear top hats to the impreza ones. You don't need the actual trailing arms, just the bracket they mount to. And they will not be the same on any 2000 or newer. It has to come from a 96-99 outback. -
92 Loyale Battled a Camry :(
bratman18 replied to pheebs314's topic in Old Gen.: 80's GL/DL/XT/Loyales...
125 ft lbs -
Again, 98-08 forester struts will work, but the 98-02 have a lower rear spring perch so you can't fit as big of a tire. 03-08 have a higher rear spring perch that allows a bigger tire, or 96-99 Outback would work as well.
Do a search for 5 lug swap.
Nice build. Are the front lift blocks built to account for camber? They look like just a straight drop from the pics, that may be why you had axle issues.
No subarus had locking hubs, and the push button is vacuum controlled, not electronic. But the dual range is definitely a better setup! Gloyale also makes and sells adapter plates for the ej swap, as well as the re drilled flywheel. And he's very helpful, and good to deal with.
Gloyale makes harnesses,and a few others.
