19
Everything posted by Crazyeights
Looks great!
Simple Lift 88 GL Wagon
Crazyeights replied to Lilblusubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome! Take a look here for 1 option. I have had the SJR EA81 4" lift on my wagon for years and I really like it. Scott makes EA82 lift kits too. http://www.sjrlift.com/ -
Old School Subies and Synthetic Lubricants
Crazyeights replied to Crazyeights's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My engines are more a work of art than junk but thank you for the opinion anyway. I don't trash your "Junk" whatever it is -
STOLEN 1988 Subaru GL Wagon
Crazyeights replied to 88SubieSnack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
These are great old cars and due to the ancient ignition lock design just about any old subaru or nissan key willl work. I have a dozen old keys or so and one of them almost always works in the cars at the yards. As in your other thread I'll keep an eye out for it in the north end. Good luck in getting it back, it looks really nice. -
That sucks. I'll keep a look out for it the northend. What is the plate number? -
EA81 oil pump removal pics
Crazyeights replied to StallonePanerai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That looks like an EA71 (1600) pump to me. -
Pull the bolts out of the pump and try rotating it slightly in either direction. If you pry on it it will usually break. If you are gentle with it maybe it will come out in one piece. -
83 GL/EA81 Suspension upgrades??
Crazyeights replied to 83subaruGLchick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have had an SJR 4" lift on my 1983 GL Wagon for almost 10 years now and I really like it. I have not had a CV boot or joint go bad in either the front or rear. I am pretty sure I used Rancho RS5000 shocks in the rear as they are longer for the lift. I am using stock struts in the front. I hope this helps. -
Do you have them yet? How do you like them?
dual range transmission rebuild vs junkyard
Crazyeights replied to d8usti5n's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have had two of them apart. One was the standard 1988 EA82 D/R and the other was a 1987 RX D/R with Full time 4WD and center diff lock. Both of them got bearings and all the seals, the D/R got 1st and 2nd gear synchros too. Just go slow and follow the factory service manual procedures to a "T". There used to be some really good right-ups on here with pictures. Putting the tail section back on and lining up the internal linkage takes some patience as does setting the backlash properly. I have lots of good pictures of mine apart if you need them. -
Awesome
I may be one of the very few but I have an EA82T wagon and I really like it. Granted I am a tech and do all of my own work. I have well over 200k on mine and it still gets me to work every day and gets good mileage too. I bought a low mileage JDM import engine for the car when you could still get them along with a full gasket set and a new oil pump. I figured the engine would blow right after I bought the car (I knew what I was buying) and it still just keeps on running. It doesn't make lots of power but I don't ask much of it either. One day it will blow a head gasket and I'll re-seal my other put my other engine and put that in. The turbo makes the EA82 fun to drive instead of a struggle. I also have three other EA series wagons with two of them EJ22 swapped. The EJ swap makes them a totally different car.
- 20 replies
- 1
Alldata does not seem to have the relevent TSB's. I couldn't find them if they are there.
- 13 replies
- wheel bearing
- bearing
(and 2 more)
Tagged with:
I have access to TSBs if you can give me a year and some specs to input I'll try for you.
- 13 replies
- 1
- wheel bearing
- bearing
(and 2 more)
Tagged with:
Hello from Massachusetts
Crazyeights replied to Mattbrat85's topic in Meet n' Greet. Your USMB Welcome Center
Congratulations! We need some pictures -
92 subaru loyale ea82 build thread
Crazyeights replied to CobCruiser's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bring it on I have three of them! lol -
Best option is probably to rebuild what you have. Contrary to common belief it can still be done with some patience in getting parts. I wouldn't even bother with an EA82. If your going to swap the engine then put an EJ22 in it. This will be quite a bit more time and trouble than fixing what you have. At 200k miles you are just getting started with an EA81
A Long Shot? A/C Compressor
Crazyeights replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You will just have to be patient and persistent. I have one of them working on my car and a spare one that came on a JDM engine (not for sale) and they both work. I have passed by several of these in the pick-n-pull yards too. Right after you give up looking for one it will turn up
