13
Everything posted by Mike104
I have a 2008 Impreza that has a vibration that is fairly noticeable at 60-65 mph. Below or above this speed is much less. I don't feel it in the steering wheel and can't seem to feel it at a specific wheel, seems to be in the center of the vehicle. I'm suspecting carrier bearing or driveshaft as a first place to check. Any thoughts?
This seems to be a common issue. Since you direct wired the solenoid that verifies that the starter and large wire to starter are good. I think you have also verified the neutral safety switch (has a different name on AT cars but same thing). What you can try is measuring the voltage at the solenoid connection when the key is turned to Start. If the voltage is low you could try adding a relay to the solenoid circuit that is powered directly from the battery. I did this for several years after replacing almost every part in the system to no avail. Since you said that there is no power at the solenoid when turned to start it may be the ignition switch or potentially a fuse.
Motor swap
Mike104 replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Turbo engine head gasket is Subaru PN 11044AA770. There is an equivalent FelPro part number but I don't know what it is. Both of those options are Multi Layer Steel gaskets that are less susceptible to leaks -
I know that the Legacy GT/OBW XT turbo engines are not recommended used vehicle purchases. Is it difficult to swap a NA engine in place of the Turbo engine? Found a nice looking one for $1000 that has bad turbo/engine. I assume that these are DOHC engines. Would swapping in a JDM EJ20 Turbo engine be easier?
Loose shifter
Mike104 replied to crperry's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's good to know. When my kid put a short shifter in his car he just pulled it out and pushed it back in. I did the same when I replaced the short shifter with the original when I sold the car. Lucky for me I didn't break the insert -
I don't think it would be cost effective to get the software to reset your airbag module. There are online services that do it for about $50. I was lucky and got a unit from a pull and pay yard and put that in my 03 Forester and it was able to clear the airbag light. YMMV. Blinking Check Engine light is usually a misfire code that can be spark plugs/wires/coil or injector issue. NGK plugs and Wires as well as OEM coils only (get one from a pull and pay yard).
Loose shifter
It's just held in with pressure. Put it in place and push down really hard and it should stay in place -
These are the two crank gears (as idosubaru said) Here are the two drivers side cam gears When I swapped in a JDM EJ20 motor into my 03 Forester I kept the original intake manifold and swapped over the drivers side cam and crank gears as that was mentioned in several JDM swap posts. Sorry you learned the hard way.
It looks like there is only one temperature sensor installed (#22630) on that year. Not sure why two different part numbers with the price variance though. Did you put in your VIN to perhaps filter one of them out? The only difference I can see in the two part numbers is one has a white connector and one has a black connector. Not sure what impact that has though.
2008 Impreza
Mike104 replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
For those codes the first suggestion is to do an oil change (that you just did). The oil pressure switches as mentioned leak oil and can easily crack the head if tightened too much. I also remember reading a long thread about those codes where there are some small screens in the valve control solenoid (IIRC) that can get blocked and cause these codes. For the misfire check for NGK plugs/wires and if needed swap in a used OEM coil from a pull and pay yard. The aftermarket ones don't taste well for Subies.
