GLCraig
Everything posted by GLCraig
  1. The NGK V-Power plugs are the OEM plug in most markets. Some US built models got champions instead but the dealerships install NGKs when doing a tune up.
  2. Check the U-Joint on the drive line from the transmission to the rear diff. When they go bad it sometimes sounds like a bad CV.
  3. It appears that the temp sensor(s) or the thermostat are bad. If the ECU thinks the engine is still cold it will maintain fast idle.
  4. The drive shaft will not swap, because the hatch has a shorter wheelbase.
  5. I've seen a couple of people run 205/60/13 before. Just make sure your wheels are wide enough to for them.
  6. I wonder if that's the place my boss was telling me about? He told me about some good trails around Scappoose.
  7. the only 1.8L engine that I know of that came with dual exhaust ports is the EJ18, which is the engine for the early Impreza. All of the EA82 and EA82T engines had just a single exhaust port.
  8. since you didn't mention hearing any nasty metal on metal noise, I would think that the transmission is just fine. With 105k on the car it's very possible that it still has the original clutch in it and that the disk is simply worn out. A clutch replacement is going to cost about the same as it would in any import car. Another thing you should do is to look through the repair history of the car. The big thing to look for is when the timing belts were changed last. They should be done at around 55k miles and if they brake, the engine will quit running.
  9. If I remember right. For no/ac you want the pump that dose not have studs. Then again my memory hasn't been the best lately.
  10. Compressed air and a dry stiff brush will loosen more of it up so you can vacuum it up.
  11. this is how the owners manual for my legacy explains the Manual mode switch. "the manual mode is used for driving in slippery condidtions. In position 3 the transmission holds 3rd (but shifts automatically between 2nd and 3rd during starting or low speed driving). In position 2 the transmission holds 2nd gear."
  12. Besides the PCV valve, check all of the PCV hoses for being plugged-up.
  13. If you dissconect the O2 sensor, the ECU will run in the fail safe mode and you'll get crappy gass mileage.
  14. The ECU is thinking that the engine is still on the cold side, so it just kicks up the idle.
  15. Just the size of the axle nut
  16. You know my 83 FSM only shows 2 cams one for subarus with manual transmission and another for subarus with automatic transmissions.
  17. I can't remember if it was 79 or 80, when they made the change on the ea71 water pump. I do know that my 80 hatch had the original engine and it had the newer style pump. When I had that hatch Subaru had different part numbers for the ea71 and ea81 water pumps. The only obvious difference is that the ea71 pump had a black pulley and the ea81 had a green pulley. Maybe there was a difference in pulley diameter or just a difference in the paint color.
  18. Gee The only thing I've towed out has been a '43 willys that had sat in the same spot in my dad's back yard for 20 years.
  19. see if you can find a set of coilovers from a 4wd wagon. They should help some.
  20. I had one of those fall out of my ea71 4wd trans. I discovered this when I drained the oil before dropping the trans. The reason I dropped it, was to replace it, because it would only shift into 4th gear unless I made a sharp left turn. After looking at some diagrams, it's pretty obvious that one of the functions of the insert is to keep the different parts of the syncro in alignment.
  21. Before you take the time to replace the gasket, take a couple of minutes and see if there are any loose screws.
  22. oops i'm was thinking of the special socket needed to get the nut off of the drive gear for the transfer case; in my earlier post. The special tool dose exists because I've used one before. You might be able to fab one out of a thick wall socket that's roughly the same diameter as the lock nut.
  23. you're probably going to need to fab one up. the subie shop i worked at had the special socket, all it is, is a thin wall 32mm???. You would be best off buying an elcheap 6 point socket and turning it on a lathe or grinding it until it fits through the hole.
  24. Dose the distributor turn when you crank the engine over???
  25. The modulator basically adjusts the line pressure of the transmission when there is a change in the manifold absolute pressure. Your FSM should have a trouble-shooting chart to help figure out your problem.
