149
Hmmm... That list of issues suck and must be a US market issue. In Oz I know head gaskets and rings/pistons were changed under warranty but have not heard of them throwing rods through blocks over here. Odd. Jeryst, do some searching on the forum. As previously mentioned there are many people/members that have effectively worked with/around the issue. Look after your vehicle, get to know it well and watch out for the signs of an issue or anything abnormal. Cheers Bennie
Incorrect. That would be the EA82, period! Many ways to look after or deal with this potential problem - one could be insuring you're not doing repeated small runs where the engine doesn't spend a lot of time at operating temp. Not flogging the engine could be another way to reduce the occurrence of a dud hg. There are many and also different options for repair or replacement... Cheers Bennie
Agreed. Poor wheel alignment will also do it, or a heavy foot and someone with no idea of how to control a 4wd slid/power slide... Cheers Bennie
^ That's awesome! I've not heard of an insurance company doing that over here... Cheers Bennie
How I cured my tickety tappets EA81
el_freddo replied to Knucklehead Saloon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Google image is your friend Jono... -
Wow! Awesome journey mate and I love the detailing on the engine and box. Kudos! Cheers Bennie
That's because they're new lifters IIRC. EA82s are notorious for being noisy with their tap pets for a number of reasons. Their general design has me wanting to put an EA81 into an L series over keeping the EA82 if I keep a 1.8 in there. Interesting. Never knew of SPFI on the EJs but anything is possible. Over here the EJ18 was/is MPFI but lacks a cam angle sensor compared to the EJ22 MPFI system. Cheers Bennie -
EJ22 1981 Brat Write Up
el_freddo replied to jimbob_goatboy's topic in Historic Subaru Forum: 50's thru 70's
If it's an 80's brat you won't need to notch the chassis/frame rails. Only the fugly series brat needs this (the 70's style brat with round headlights - quad from memory). Cheers Bennie -
That may be true but our design laws can be very different to NZ. Subaru Australia calls the shots as to what is offered and what is not. Eg: we didn't get the L series RXII coupe, or any L series coupe for that matter NZ did. NZ also hasn't had a local car manufacturing industry for a very long time and have relied on imports. I believe this includes second hand imports. They have MANY exotic JDM delivered goodies that we never got from factory over here. And whe they're close to us it's very costly to import vehicles in to Oz personally. Laws make it hard and it seems everyone on the docks/wharfs has a hand in your wallet if a vehicle is imported. Forget the carb'd EJ factory unit. I'd be going for the RXII coupe if could ever import something. Cheers Bennie
True. There's correct tappet adjustment tapping and the tapping noise of tappers that are out of spec. If the impact surfaces are worn you'll never get them sorted with feeler gauges as directed in any good service manual - it comes down to trial and error by feeling for the gap. Anyone pulling the heads off: get the contact surface of the rocker arm checked to ensure they're smooth/flat across the curve of the contact face. If there's a groove in there get rid of it! Cheers Bennie -
The mystery rattles and the short term smoke
el_freddo replied to Paperscale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Another thing it could be is the oil filler pipe lid rattling. Newer cat doesn't mean it hasn't died. I don't know the age of the cat or how your weather treats exhaust systems over there but over here a new cat should see out the life of the vehicle in general. Cheers Bennie -
If it hasn't been removed, there's a little tap device near the alternator that manipulates the flow through the intake heating circuit. Both have been removed from ours as they were super brittle when the hoses were replaced. I didn't think to replace them with a new tap and run it as ON in winter and OFF in the summer months. This could be worth looking into. Also plumbing the smaller hose from the water pump through the auto fluid warming circuit wouldn't do much other than cool your heater circuit fluid. I don't think it would achieve much in the end. Cheers Bennie -
Dead fusible link? I can't remember if the charge wire goes through the fusible link. The reference wire certainly would. I'd be checking these to ensure they're all in good health. Cheers Bennie
So you're running a weber carb? I'm still running factory on both our brumbys. I was going to ask how much shaft play you have in the throttle shaft of the carb. My theory is that the shaft or the mount wears out allowing air into the carb that leans the mixture out. I believe this is most noticeable at light throttle on inclines. If your temp gauge is going over half way there's and issue there. The Thermo fan(s) should kick in at the half mark (too hot for my liking). Since posting about mine not pinging, the other day when it was 30+ degrees it pinged under heavy throttle when pushing it up hills fully loaded with a loaded trailer in tow. Not too worried as this was to be expected in those conditions. Cheers Bennie -
No spark = no fuel pumping. Work out the spark first then go from there... It's better to have spark and no fuel when trying to set something started IMO. With the replacement dizzy, points or module? If module replace it. If points make sure it's wired in properly and the gap is adjusted properly too. You may need a different coil for the two setups, I can't remember this exactly as it's been ages since I've played with the two systems. All the best Bennie
Dead cat converter. When these break up internally they can rattle around under load. Give it a gentle tap and listen for rattles. As for steam if it's cold weather you will naturally see vapour out the exhaust until the engine and exhaust pipe has heated up properly. At least that's how it works down here. I know in some parts of the states the exhaust always gives off vapour in winter due to how cold it is and the exhaust pipe not getting up to full temp. If you've got coolant in the cooling system and your exhaust smells like something sweet but not right sweet you've got a coolant leak into the combustion chamber which usually means a head gasket. Cheers Bennie -
EJ into EA81 - bonnet clearance, standard height
el_freddo replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Going back to the original question at hand. It's been bugging me... I'm 99% sure that Tim ran an EJ turbo conversion in his MY and this is the reason for the one inch spacer - you need this to allow the bonnet to clear the intake manifold which is different to the NA EJ. Do some more research. I reckon you'll find that any EJ turbo conversion in a non lifted MY will have these spacer blocks on the engine crossmember. But NA EJ conversions will not have them. Cheers Bennie -
I think a lot of the carb EJs went to Latin America and probably to the old European block countries. All of our EJs are injected including the EJ18 that came in some early front wheel drive imprezas. I don't think we got the ej16 here but have heard they exist. Cheers Bennie -
What models in USA or elsewhere got Diamond A coils?
1991 EA81 Brumby (targa). Noticed the little symbol on the coil while hooking up some lights. Cheers Bennie -
Hmmm I always thought the tappet gaps closed as the engine gets hotter due to the push rods expanding when hot... Anyway, if it works for you stick with it. I have one tappet that I just cannot adjust correctly. I can put up with one ticker Interesting about the pinging at light throttle under load. I've been trying to work out how to cure this in my mother inlaw's brumby. I haven't had it occur in my brumby - yet... Cheers Bennie -
How do I wire up '95 EJ 22 just for spark?
Someone correct me if I'm wrong but I'm 99% sure on the early auto EJ ECUs there's a particular pin you ground to tell the ECU that it's a manual gearbox. I've not read too much into it as the loom I've played with is from a manual. I like where you're going with this thinking but I reckon you'll run into issues with error code for injectors. Someone may know a way around this, most likely with a resistor of a certain ohm rating per injector. It may need the TPS hooked up. AFM who knows... Have a read on Ausubi (use Firefox or old version of explorer) with the EDIS system the Silverbullet has setup on his EA81S in his wagon build. I don't think it's really that financially involved. The biggest hurdle for him was creating the crank sensor's wheel. Cheers Bennie
