Everything posted by Flowmastered87GL
The End of Yokohama Geolandar A/T-S - in Subie Sizes?
They still have these... I think they are the next generation maybe. (reading the response above from Tire Rack seems to back that up) https://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=Geolandar+A%2FT+G015&partnum=07HR5G015&vehicleSearch=false&fromCompare1=yes
- My Free 86 wagon
$1.00 1996 OBS!
100K finally!
CANT UPLOAD PHOTOS!
We can't actually host pictures here on the site. Best option is to host them somewhere like photobucket and then link the picture.
Rosey the Forester - My new family helper
Ah ok, can't tell they look really good in the pictures.
$1.00 1996 OBS!
Pretty sure the car is going to get a Primitive Racing skid plate thrown on and I am going to run this event with "Hondasucks"
If those gold rims are US spec... they are super rare and worth quite a bit... 1998 RS only. (1999 went to silver)
Does Subaru have big dealer hold backs and incentives?
There is not $5000 of padding in a Subaru. My parents just bought an Impreza and it was more like $1200 if I recall. They got the car below invoice plus I was able to get a $500 Subaru Ambassador coupon to apply on top of that. The dealer should be willing to show you the invoice. Often times if you contact the INTERNET DEPARTMENT, not retail sales, they will give you a very good quote over e-mail and tell you what invoice is. (I think the two bids I got were $200 under and $500 under) http://www.cars101.com/ used to show the invoice prices, but I couldn't find them tonight. If you dig around on there maybe you can find them.
Buying first Subaru, what to look for: 1987 Subaru GL Wagon
Expect the car to need at minimum: Timing belts and water pump. The timing belts especially are problematic on these cars. In around 135,000 miles of use of a GL I had the timing belts break on me twice leaving me stranded on the side of the road. On most of these that I had I commonly threw head gaskets, all oil seals, water pump, thermostat, plugs and wires, water pump at the car before being able to trust it. I love the GL series... but General Disorder is right... something newer like a Legacy or Impreza is going to be significantly more reliable.
- '03 Impreza Outback Sport
Lifted Rigs 2017 Roll Call
1996 OBS. 3/8" ADF strut top spacers 1997 Legacy Outback struts 1997 Legacy Outback rear trailing arm mounts 1997 Legacy Outback rear sway bar and mounts 1997 Legacy Outback tires/wheels Kartboy STi rear endlinks on front sway bar Whiteline rear camber bolts
The Unofficial "How to Lift your Impreza" Thread
I'm not surprised they are rubbing, I have 205's on mine and 15's and I BARELY have any room. I can't even fit a finger in there. You may need different offset wheels. Hopefully someone else has another solution, but I just barely scraped by on my clearances.
My tie rods are bone stock. My alignment setup was done as a "1997 Legacy Outback" Per Firestone.
HELP - 05 Impreza Lift?
This covers a little more the older models, but it still has some good information in it. http://www.ultimatesubaru.org/forum/topic/118004-the-unofficial-how-to-lift-your-impreza-thread/
1996 Rear Wiper motor Replacement nightmare
Flowmastered87GL replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry a nut from the front... it just might be the same size. If it is you can take that nut into the hardware store, fit a bolt that it fits which will tell you the size and pitch. Then find a nut with those specs. Its a roundabout way, but its how I figured out what my shifter was years ago on my GL.
New to us '00 OB Limited
It doesn't look too bad. With any luck a new hood, fender headlight and some hammering to make sure the core support lines up and you would likely be good enough.
information about reliability
It should be decently reliable if its been taken care of. Since its turbocharged though everything under the hood is subject to increased wear. The CV boots will wear out faster, hoses will wear out faster, belts wear out faster, the car needs oil changes more often, etc. If you take care of the car it will take care of you. The most critical thing to make sure has been handled is the timing belt. Done with it should be the water pump and all the timing belt pullies and tensioners. I personally would take a non-turbo car over a turbo one every single day of the week as far as reliability is concerned though. But since you have the car already, all you can do at this point is make sure the car is meticulously maintained and it should be decently good to you.
Bucks on acceleration
My 2005 Baja had been bucking on acceleration if I got on it too hard. New plugs and wires fixed it in my case. I did the tube seals too so the oil would not eat the new wires. I used all OEM parts.
Towing a trailer, Oregon to Pennsylvania
Probably a good idea. Towing all the weight will be really hard on the car. Plus with the way EA82's are it will blow a head gasket or break a timing belt when you are in the middle of nowhere. I have loved all my EA82's, however they were not particularly reliable.
$1.00 1996 OBS!
Got some toys for the car for Christmas. Pictures coming after they are installed. Car will be getting new Kenwood speakers to replace the 21 year old paper units. A roof rack basket A trailer hitch with shackle recovery point
With the way they salt the roads there I wouldn't use it either!
I have an Opportunity...
Flowmastered87GL replied to NV Zeno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have Russ / Richie do the repair up here in Portland the odds of success are better, but it will still likely fail at some point in the future. My Baja has 184K and has some major oil seep from the head gaskets. I am hoping to nurse it to 210K, reseal the engine and then run it til it blows, then replace the engine and so on. Personally I would do the timing belt, ALL oil seals, tensioners and water pump with the head gasket. Even if they are a year old you know they were done right with quality parts and you should not need anything besides plugs and fluids for the next 105K The wagon you have will likely be slightly more reliable, but either one is a good solid car.
Ea82 overheated / head gasket question
On all the GL's that I resealed in the past I just took out the engine, took of the heads, inspected them for cracks / warping, (never had to do any machine work), put in new head gaskets, all oil seals, water pump, and timing kit.
2003 Baja
Good to see another Baja here. Mine has head gasket seep too, but I have not changed them yet.
I don't know if I should buy used or new
If you are really looking into late model stuff I would go for a new model. Around here in Oregon you can often buy a brand new car for less than a used one. Example: My parents just bought a 2016 Impreza Sport Premium CVT in August. They paid around $21544 out the door brand new. Used models one or two years old equipped the same but with miles on them were "asking" $24000 and up. My parents got this deal on the car with no hassle at all... I just asked them to tell me what specs they wanted on the car and I contacted a dealer via subaru.com. The lowest bid was about $500 under invoice. I piled a $500 Subaru Ambassador coupon on top of that, they paid cash and we got a heck of a deal with no negotiation necessary. I will note that we kept the paying cash deal a secret until the very end. We used Miguel Mesa at Carr Subaru in Beaverton Oregon (in the internet department)
