nipper
Everything posted by nipper
  1. I think the square lines of the 80's wagons look GREAT in camo!
  2. Has this happened before? Was it 3 seconds of continous cranking or 3 seconds, stop, then retry and the car fires up.
  3. http://www.ultimatesubaru.org/forum/showthread.php?t=106244&highlight=Tick+Death
  4. Coolant temp sensor. Car cant tell how warm it is nor how cold it is so it is running too rich. Subarus dont usually burn oil, replace the PCV Valve.
  5. All soobies need matching tires of equal wear. All rubber parts in the front of the engine should be replaced, along with all the parts suggested. That humrr is a rear wheel bearing. The exhaust noise may be the flex joint in the exhaust system Oh and i hate you for finding one,
  6. Front O2 sensor should always come from Subaru, and this is the reason why.
  7. 2.5 DOHC is an Interference. Only 2.2 of that year were not. Belt snapped bad.
  8. I usually replace them in pair, and i also recomend that. They both see the same amount of work, and bsically are built the same except one has a resivoir. nipper
  9. Oil pressure is useless in your case, as pressure stays consistant as long as there is oil in the crank. Check the oil once a week.
  10. They are really cheap, you can use a dash gauge (19.00 ish) and we can learn alot from that.
  11. One qt every 1000 miles is still considered acceptable for an engine. You have to learn to check the oil at every fillup or once a week, otherwise say goodbye to your engine. You may have bad vlave seals, weak rings, worn guides. DO you have a vacume gauge?
  12. wel since you are using that much oil, it is foolish not to check it at every fillup. Do that it will help us figure things out. has the car lost any power?
  13. Oil burning won't fail emissions. Catalytic converter hide all sins till they clog. When you did the timing belt again what else was done? seals? water pump? Oil pump? Is the oil on the end of the spark plug wires. Once again how many miles between oil changes. Change the PCV valve and check to see if the hoses are clogged. After that we have to look deeper. How many miles per qt are you getting.
  14. Wash the bottom of the engine to make sure there are no leaks. Subarus can be sneaky. How many miles. How many miles since the last oil change When was the last time the timing belt was done and what was replaced. Replace the PCV valve. Have a freind drive behind you for 30 minutes and lets see what smoke you have coming out under hard acceleration and coasting.
  15. Any CEL ? Could be you alread have one bad VSS and the other dying. Could be a bad ground in the cluster.
  16. Usually when the slave goes, the master should be replaced. With the free play was the slave cylinder extended?
  17. nipper replied to rpholz's topic in Subaru Transplants
    As opposed to installing it? In comparison thats a breeze
  18. A flywheel has several jobs. One is to keep the engine spinning at idle. Another is to help absorb vibration at speed, and the last one is to attach the rest of the driveline to the car. If the flywheel is to thin, the harmonics (vibrations at X rpm) may be changed. 4 cylinder have specific RPm points where they "bang" or "Roar" . You can hear this when you stomp on a 4cyl's gas pedal. this is why there is all this wierd snorkus tubing, to try to reduce this noise. if you look 6 cylinders or more do not have this. That Roar can also affecxt engine vibrations if anything is fiddled with. I can not say 100% if this is what it is as I have not driven the car, but after everything else I would suspect this.
  19. All engines are internally balanced. Subarus more so as far as wear is concened. Is this a new flywheel or a resurfaced flywheel? Have you tried removing the accesorry drive belt then watching the harmonic balancer? Possibly a bad valve adjustment? Have we done the vacume gauge thing yet?
  20. YAY all I could find is a sears for 75.00 a popor 25.00 a pop. From Justy's Dustys: What most people don't realize is that any size rim will fit under a Justy's stock fender well up to 23x8." The problem is tires, they don't make 'crazy' sized tires and wheel offsets to support these kinds of configurations. Many wheel/tire packages may require trimming if too tall and/or rolling of the fenders if too wide to prevent scrubbing of the fender wells. Most any 12-14" will fit properly, the problem is 12" tires are almost non-existent, and some 13" tires are hard to find. 14" is honestly ideal and tires are easy to find, but rim choices are limited to other OEM swaps, such as a Honda Civic or Ford Escort wheel. (Note: The 91-95 Escort 14" 8spoke alloy is a nice wheel, and what I used on my personal Justy for many many miles)! 15" require readily available low profile tires. 16" require harder to find low profile tires while the correct 17" has just one size available and will scrub. We recommend a 14" or 15" swap... the 16" rides a little bumpy and the 17" is insane and will affect ride quality and braking. Correct tire sizes are listed below along with other available sizes that will work. All sizes listed below will fit under a stock wheel well, but some may scrub a little when turning or going over a rough bump. Some are be a hair too short or too tall and may affect your speedometer reading up to 2mph. This is perfectly drivable, but be warned! Be sure to measure and measure again to make certain the tire you want to use will fit especially if your car has been modified or is lowered! 12" - 145/80R12 is correct size. Stock wheel. 13" - 165/65R13 is correct size. Stock wheel. 14" - 175/65R14 is recommended size. (What I Used). 15" - 195/50R15 is recommended size. 16" - 195/45R16 is only size readily available. 17" - 205/40R17 is only size available, period. Rim SizeMetric Tire SizeHeight in InchesWidth in Inches 12"145/80R12 (stock)21.15.712"165/70R1221.16.512"155/80R1221.86.113" 165/65R13 (stock)21.46.513" 185/60R13 (recommend21.77.313" 165/70R1322.16.513" 175/70R1322.66.913" 155/80R1322.86.114" 185/60R1422.77.314" 175/65R14 (recommend)236.914" 195/60R14 (tight fit)!23.27.715" 195/45R15 (don't use)!19.97.715" 195/50R1520.77.715" 195/55R1521.47.716" 195/45R16 (only size)!22.97.717" 205/40R17 (only size)!23.58.1
  21. nipper replied to rpholz's topic in Subaru Transplants
    There is always a US Surplus tubine or jet engine
  22. nipper replied to rpholz's topic in Subaru Transplants
    There are some very small V-8's around http://www.roadcarvin.com/hartley-enterprises-v8 Or better yet, a large V-6
