Everything posted by Scott in Bellingham
Gen 1 EA71 Lift kit 4" SJR now Available
Made up my first Gen1 4" lift kit, fits the 1978-80 Subarus with the EA71 1.6 engine , its now a catalog item see here http://www.sjrlift.com/index.php/catalog/lift-kits/0-4-lift-ea71-detail
JUSTY Lift Kit Now Available SJR
Cool! Let me know the dirrerences so I can incorporate them in the kit
- Reproduction Vintage BRAT Shirts
Wiring EJ swap - ECU wires
Ive done a few conversions and always just left those wires unhooked,my cars seem to run just fine.
Will do , after the customer gets her done
Just made up my first Justy Lift Kit its a 4" , they can be ordered here http://www.sjrlift.com/index.php/catalog/lift-kits/justy-lift-kit-4-detail
It was bound to happen
the more trail time I get the better I get at driving
Need front hubs for '82 Brat
I have one ready to ship, may have another PM me
ej22 swapping a brat
Short list EJ engine Redrilled EA82 Flywheel , clutch pressure plate EJ - EA adapter plate EJ exhaust y pipe Stock EJ wiring harness with ECU thinned out to just the engine circuit I sell most these parts and services at www.sjrlift.com Scott
Baja build nearing completion with lift, tires and wheels done!
yep I agree
ea81 vs ea82 weber carg
EA81 today, EA82 under development, be a few weeks
same weber different adapter plates
- Weber EA81 Carb Adapter SJR NEW Product For 2016
Lifting the Loyale 8" ?
With a EJ22 and a dual range your gears will be ok, no need for a second transfer case , I would go EJ 2.5 before I T cased it on a road car
I had that same issue with grass in a clutch years ago on a Subaru buggy , great story!
- I'd like to try to make a side by side buggy.
Lifted 2000 OBS
been there done that
Lift block height
not to add to much pressure but its been 2 years lets see this rig on the trail soon! , as far as a removable crossmember or other removable parts a cut off saw and a welder makes all the parts removable and replaceable, just get this thing back in one piece , you will make a few mistakes but that can be changed later too, what do you want a project that goes on and on ? or a machine you can take out and wheel with your buddies? Your choice, no more excuses we all want results .
An unfortunate discovery
You can weld up the shaft, not the key, then file the hole correct
97 Outback Impreza Sport Suspension Lift
Run forester or legacy outback struts
- its hammer time again
