163
Everything posted by lmdew
Get the #'s off the two transmissions and look up the gear ratios. There is a 2 letter code on top of the rear diff that provides the gear ratio but you have to pull the diff to see it. Larry
If the fluids have mixed and they have been driving it that way you may have bottom end damage to the bearings without proper lubrication. If you put the money in to the HG and then a rod bearing goes you will not be happy. If they want to keep the car you might think of a total rebuild or used motor.
- 10 replies
Could be high resistance in the relay contacts. Again checking the voltage under load at the headlight is the best way to figure out what's going on.
- 8 replies
- lights
- headlights
(and 1 more)
Tagged with:
Check the connector on the lamp itself. Lot's of times the connectors are loose and there is high resistance. I've seen lots of them melted. Check out, www.brighterideas.com I bet you have a voltage drop in the system. LoadPro will find the fault.
- 8 replies
- lights
- headlights
(and 1 more)
Tagged with:
Did my 2001 2.5 SOHC heads today. I used some Corian Counter top I'd cut for cutting boards, flat as glass I believe and spray adhesive. The Loctite General Purpose spray adhesive worked great. I started with 180 grit until I had all the marks gone and then finished with 400. That's what I had on hand. If anyone wants some 8.5 x 12 Corian I have plenty. $5 each + shipping. Buy two one for course grit and one for fine. Better get a couple for the kitchen also. Larry
What have you found that works well to remove and install the Subaru Valve Keepers? The old tried and true method of removal works well but there is limited space for a valve spring compressor to install the valve keepers. Here's one i found: http://www.ebay.com/itm/Lisle-Corp-New-Magnetic-Valve-Keeper-and-Remover-Installer-Tool-/400591129879?pt=Motors_Automotive_Tools&hash=item5d45178d17&vxp=mtr
96-99 DOHC Internal HG Leaks, blows out all the coolant - the worst I'd say 2000 and up 2.5 SOHC External coolant or oil leaks at the head to block seam, less of a problem then the DOHC engines but still will require HG at some point if leaks start. Use Coolant Conditioner from Subaru in these engines. Look for external leaks and ask if the HG have been done.
Grip Force Clutches - Ebay, I've used lots. Search this form, lot's of good information on doing the T-belt and seals, a seal puller does make the cam seals easier, but you can do them without them. If the HG are not leaking, leave them alone unless you have extra money to throw at the engine. Yes they may start leaking but you may also get years of use out of the engine with no leaks. I'm always of the mind set if it's not broken don't fix it.
Yes, you could do it. I'd first check and see how bad the leak is and if it's Oil or Antifreeze. Clean the engine well and then park over a sheet to collect the fluid. Small leaks can go for a long time without much of an issue as long as you keep the fluids full. Do a search on the USMB and you will find lots of good information. Have you done your Timing Belt? If not you can do it all at the same time. If you take it to a shop, make sure they specialize in Subaru's.
Did you by Outback or Forester Struts? If so the majority of the lift comes from the longer bottom section under the spring seat. I have good rust free springs, I can send you. Sedan the top mount bolts are behind the back of the rear seat Wagon, pull the top plastic cover just behind the rear seat.
