30
Everything posted by Turbone
If the death of one keeps others alive, its ok in my book. I looked at your web site and I noticed that the MY84GLF is what we call a Hatchback. The GLF is a 2 door coupe, something like the 4 door sedan. This is what mine looks like
I guess I'm not the only one who doesnt read well :-p
score at the junk yard.. rare find :P
Turbone replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very incriminating evidence, look at the speedo On my 86 T-Wagon the square plate to the right of the CC switches (my rear gate lock/unlock switch) is where the factory foglight switch is. Its almost like the old EA81 Centerlight switch, except its orange. -
I think theres enough yuppies around here that I could get rich! I'm gonna sell canned mud!
West Coast Subaru Show 7 Thread (real deal)
Turbone replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
Only in the mud pit:D -
If this place ever gets close to resembling Nabisco, I'm outta here
Welcome fellow Subaru owner and curmudgeon! I thought I was the only one here, the others wont admit it Hope to see you at the Show
Dont think theres going to be any overnight stays for me, I will come down in the morning and stay as long as possible both days. So I will be able to bring a different car each day. -
two bent rims, what up with this?
Turbone replied to pyromanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How old are they? Metal fatigue will happen easily after 20+yrs. -
@ Ed. Thats Austin's old wagon of course. It now resides in MI with Noah. I've been stumped tho since you posted it, but it just came to me. It looks like some of the schemes from the ships in Homeworld.
There is only 2 bolts for the motor mounts. The 2 nuts on the bottom of the bellhousing are a PITA, you need a open end wrench or remove the axles (which you need to do anyways. Just remove the PS pump and set it aside, easier that way. The other point to attach a chain to is the pitch stopper brace.
XT6 and EA82T flywheel timing marks differences
Turbone replied to Marck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It is different because of the 2 extra cylinders. I think if you put the 2 flywheels together and transpose the marks from the EA82 to the XT6, it should be right then. -
Careful you dont give yourself another hernia If I had done all that, I would be flat on my back for a week. Stupid back
missing the HP meets..
Turbone replied to Ratty2Austin's topic in Meet n' Greet. Your USMB Welcome Center
Austin, I would look forward to seeing a DVD of HP stuff Maybe we can arrange a little outing before you go east? -
Luckys first road trip..on her own power!!!!
Turbone replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is she good enough to be your daily driver yet? -
Those pics just re-inforce the urge to lift a Coupe
Someone drilled holes in my exhuast pipe.
Turbone replied to blinkibus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think they drilled holes in it because the cat is plugged. Its all in the gearing -
need front end help AGAIN
Turbone replied to myfinalcoffinx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have stripped out a nut once (on the axle, guys) -
EA 81 Turbo - Timing gears ever jump?
Turbone replied to jamesp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You need to pull the disty back out and then set the number one piston at TDC, on the compression stroke. You can put your finger in the hole and feel for the air coming out, that tells you its the compression stroke. Once you have it there and if you havent messed with the spark plug wires, you can set the disty rotor where the number one sparkplug wire is on the cap. This should get you close enough to get it running and then time it. -
If I dont have access to a air compressor for my air gun, I usually take my 1/2 drive breaker bar and slip a 3ft long pipe over it. And I hurf down on that sucker as tight as I can, just making sure I line up the hole for the cotter pin. Havent had one loosen up for quite some time now. -
I have a 86 GL-10 Turbo Wagon with the pushbutton single range 4wd. Its a good hiway/daily driver car, have never had any problems with the tranny.
The cone washer could be wore out and sometimes the outer washer can be placed back on the axle stub the wrong way. Yes, there is a right and wrong way. -
You got a PM.
