105
any codes stored?
Hall Effect but, I think it is more like a reluctance sensor???? anyway, probably need a o'scope to test properly. sure there's no spark? - if the car cranks, try a little starting fluid
how's the rust/corrosion issue look underhood? maybe refresh some ground connections and check alternator voltage. does the '12 manual suggest running high octane fuel? maybe the fuel pump is getting weak or there's a problem with the regulator? if possible, have a shop look at live data. maybe a:f is off or the ecu is retarding timing.
- 19 replies
- 2012 outback
- misfire
(and 1 more)
Tagged with:
NASIOC and friend in the same sentence seems odd - lol! But, yeah, there'll be good info there somewhere. I have already discovered the link in 06 - up may have replaceable bushings at all 4 locations. Turn-in Concepts has some bushings. Watched one video on console removal but, my car looks a little different. Hey, looks like the boot and shift knob unscrew together? is there aset screw or something? are the threads 'clocked'? how to reassemble without the knob pointing some odd direction?
as said above, catch-up on maintenance, give it some TLC, go thru and refresh all the ground connections, maybe a new PCV valve, maybe a spray-type SeaFoam treatment (with the u-turn nozzle) , a can of Techron in the next fill-up. If you do plugs, stay with NGK. Brake pads should be name-brand ceramic. any 'system' you work on, search/ask here first for tips/tricks. stickier tires may be the best upgrade you can make.
- 12 replies
you can make it more fun to toss around the corner; stickier tires, new struts, maybe stiffer springs and perhaps a rear anti-sway bar upgrade, lighter-weight rims are a good way to free-up a pony or two AND personalize the car. don't carry unnecessary weight in the car. find the local SCCA chapter and auto-cross the car. fun, cheap, safe.
- 12 replies
Hey from Minnesota
1 Lucky Texan replied to Optimus8304's topic in Meet n' Greet. Your USMB Welcome Center
howdy! -
can you describe or post pics of the damage? any problems during the work? brake hoses get twisted?
P0420 can be caused by other issues, some of which may not throw a code. OF COURSE an older car could need a cat. just that, vacuum leaks, exhaust leaks can also throw that code. many folks have had cracked/bad knock sensors that didn't throw a code. Plus, regular misfiring could explain poor mileage AND the excess unburned fuel could have destroyed the cat. the rear O2 sensor is what 'monitors' the cat, it or its wiring may be bad. Cats are pricey, never change one based ONLY on the 420 code, there are other tests that can help pin-down the problem.
6 speed trans and I guess rear diff from a spec B...+ built/tuned WRX or Forester XT engine from a wreck could be a really good swap.
- 14 replies
- sti
- manualswap
(and 2 more)
Tagged with:
