Everything posted by subiemech85
Replacement Driver Seat Foam ???
subiemech85 replied to 4RnrRick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
beaded mat, walmart $5 chair seat cushioons walmart $5 seat cover walmart $5 -
Anyone know where this goes?
subiemech85 replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ebay -
Starter Compatability
subiemech85 replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you must watch out, as the "as origionally equipped" makes a difference, there may have been at least 4 "flavors", california, auto, manual, trubo, but they "should" work, may need spacers -
sending you a pm VIN: JF1AM43B7DB431156 Year/Make/Model: 1983 SUBARU GL ????mystery????
you just opened up a new can of worms, start shaking and looking, good luck
No idle with less restrictive intake?
subiemech85 replied to Tachometer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I could only think of choke -
1. it is NORMAL to feel significant resistance while turning the wheel if you are stopped or moving slowly, it is MANUAL steering the noise may be the clutch cable hitting the steering shaft, very likely and common your WIFE needs to exercise her mite, or try a different technique 2. the problem is YOU DO NOT DRIVE ON HARD SURFACES WHILE IN 4WD IF you find it nearly impossible to shift out of 4WD, try driving up on a slight hill, set the parking brake, shift into reverse, and work the lever
?? does a FORD PINTO carb replace... :brow:
subiemech85 replied to subiemech85's topic in Subaru Retrofitting
no, it is more than just clearing the dist you have to extend various wires, coolant temp, oil pressure, etc. swap throttle cable bracket remove and plug the bypass line that goes to the t-stat housing, reroute bypass lines remove the tab by said bypass line remove metal on alt bracket mix n' match emissions lines use ea82 upper rad hose, air box and other tidbits trust me, I've done it I did NOT do anything to the dist. quit HIJACKING this thread -
Another one bites the dust.
subiemech85 replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks to me like the turbo puked the wastegate, what else would explain the location of oil? -
QuikSteel use on exhaust....
subiemech85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and while I was driving, I thought why not cut a can to fit, spraypaint? -
just run open ports what happened to the other spacer? -
strip off the plastic to reveal the thin metal and drill the correct size holes, it works
will a ea81 radiator mount into a 87 wagon?
please DO NOT DROP, insert gently I could visit after 4 today -
the jump up is the button you push in on the left the tilt is the lever that is above your knee
Air filters? Stock Box/Cone/Snorkel
I'm not sure what the tray is, but when I had to drive in serious rain, I ran the hot air intake pipe from the warm air intake port of the air box to behind the carb, and set the vac line so it did not take in fresh air, ea82 -
an ea81 carb?? I'll see about that, they both have hitachi chokes, appear to have the same bolt pattern, and are made in JAPAN Only major preliminary differences is the float level window is 10x larger on the ford, and it uses a round air cleaner
I prefer purolator . -
moonshine? everclear? fermented RICE? if using "RUBBING", it is 30% water, 100% is available what about ethyl, methyl, and others? propane injection is for diesel, works like nos for gas
heater controll question
subiemech85 replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the round ball thing is a reservoir, holds vac to run accessories when you have no engine vac, that is your program -
Online factory service manual (FSM)
check your fuses, fuel filter, sparkplugs -
unscrew the back walmart sells a replacement, $5
exhaust gaskets, joints, rust is it so bad you must either A. keep the windows up, or B. avoid idling in place ??
Immediate Opinions Needed!
subiemech85 replied to Seahag1978's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes, do it ALL yourself, or with VERY GOOD help, that way YOU blame YOURSELF, and LAUGH at yourself
