Everything posted by Numbchux
Motivation to repair
definitely start small, take little bites off it. you're still ahead of me. going on 2.5 years that I've owned my 4Runner.....and I've never driven it beyond the end of the alley. how's that for motivation in other news. an EJ22 with an EA82 radiator will not overheat that easily. a second fan is a band-aid. maybe your piping is the cause...maybe it's something else. the fan on my wagon doesn't get used almost ever. regardless of temperature (even in the summer), as long as I'm moving more than ~30mph, it stays cool. period. I say cross that one off your list, at least until you've put a new tstat in there and fixed the radiator hoses. neither project is very big or hard. that'd be a good place to start. and not having it overheat is a good motivation to drive it!!
I long for the boost love
naw, the DL lights look awesome on an offroader. but I don't think they really work on a lowered car. I wanted a set so bad for my old blue '88 wagon. but hvae no desire to do that to the Frankenwagon.
Photoshop my Project XRBrati
played with a couple filters.....found something that gives it a little more definition kind of like the reflection off a glossy finish would. but most of that depends on how much reflection there is in the original paint job/picture.
side-by-side I think that's fairly close....other thoughts/ideas?
I agree, it's too light. working on darkening it. I've also added a gradient layer so it isn't so much lighter on the front fender. and a mask over the rear bumper so it's the same shade as the rest of the body.... will post another version in a few minutes
I've been tinkering with it. got a decent mask of the body done. then some "body work" to get it all one color without loosing the definition of the body lines. I'll keep working on it. EDIT: removed some of the other imperfections in the body. did the black hood and started on the orange body. I'll have to play with it some more to get it the same color...but here's an idea:
Is this just a regular EA82 coupe..
it looks like there might be a red decal on the lower part of the door and just behind it. if so, it probably says "4WD Turbo", or something to that effect. or it's just rust.....:-\
tribeca struts on a 1991 legacy
I highly doubt the tribeca stuff is any longer than outback stuff. do you have outback springs on there too? those will yield a bit of lift as well.
Post pictures of your EJ swap
hmmm...the ford pump plugged right into lines on the '86. all I had to do was throw a couple real screw-on clamps on there. might have been a fluke with the ford pump though. that pump came with all brass fittings, so I'd assume they're safe to run fuel through
is there an easy way to replace antenna wire?
nope, it plugs right in. but the stock radio has a pigtail that it plugs into, so the stock wire is not long enough to reach an aftermarket deck. but re-routing the cable through the dash instead of under the carpet solves.
Is a little bit a metal in the oil pan normal?
hard to say.....yea, normal wear will cause some metal flaking. but enough to actually collect in the oil pan? when I pulled the pan on my 250k mile EJ22, there was no sign of any metal in the oil. *could* be a sign of something worse. the engine might be fine for quite a while. hard to say.
1985 Subaru Brat Suspension Upgrade
haha, street beat. that's where one of our members (wow....can't even remember his name now. been so long since I've seen him around) got the ragtop he had in his lifted wagon. anyway. $1k is a pretty darn good price for a setup like you're talking, and I HIGHLY doubt that ones strong enough to hold up to more than a few minutes of rally abuse. although I don't see that big airbag fitting in the rear wheel well of a brat.... also, the shocks have nothing to do with ride height in the back. it's all in the torsion bars. you could add a helper of some sort, but something designed to hold up the weight of a car is going to be far too stiff in addition to the torsion bar.
shock question with SJR 4" lift
well, the Rough-Country equivalent shocks we put in my buddies 4" lifted brat where for a 2-3" lifted Jeep TJ Wrangler. so look for some that fit that application.
a rather noobish question
I see you're in North Carolina. I believe there are a few members out your way. dropping another stock motor in there would probably be a pretty quick job. having worked on them for years, I could probably have it running in a couple hours. somebody without EA82-specific experience but decent mechanical ability could do it in a day pretty easily. and getting hold of a running used one (don't be too afraid of the mileage, they're fairly tough. 200k+ isn't too hard. also, if you do the swap and it sounds like hell when you first start it up. don't fret, the hydraulic lash adjuster take some time to work fully, so you'll get some crazy valvetrain noise until it's been running for awhile) for a few hundred bucks wouldn't be that hard. if you're looking for a fun, reliable car that's going to get great mileage. an EJ22 swap is an awesome option. I did a swap into an '86 wagon last summer, part-time 4WD, and it's trip back to Michigan, it got 32mpg. 135 hp, and worlds more reliable than the stock EA82. it's not a terribly hard or expensive swap, in the grand scheme of things. but it will take up some time and some spare income. so if you're looking for a quick, cheap turnaround, it's not a great option.
they do use the larger 5x114.3 lug pattern (compared to your 5x100 on your legacy). so I suspect they use the same (or similar) knuckles as the '05+ STis (which are also 5x114.3). which I know is not compatible with 5x100 stuff. also, I don't remember. does the tribeca use struts in the back? or multilink and coilover shocks like the legacies and '08+ imps. if it's the multilink, then the rears will definitely not work, in any way, at all long story short, maybe. but there are so many other options that will work much better. what are you looking to do with your car? lift it?
it is one piece with the antenna itself. but it's not very hard to replace. I pulled one from a junkyard in about 10 minutes, and swapped them out into the '86 I had this last summer in about 25. pull off the a-pillar trim. pull off the little sticker. use a deep 8mm socket (I had to buy this just for this project....ugh) to disconnect the antenna itself from the car. then carefully pull the wire out (or not so carefully when removing the old, already broken one). the only hard part of re-installation is getting it to pop out the little hole at the base of the a-pillar. the stock wire goes down under the carpet in the footwell. but if you re-route it through the bottom of the dash, you can get plenty of length for an aftermarket deck (I've done this on all my EA82).
Older Generation Becoming Historic?
diesel is a very close cousin to the EZ and EJ motors. sharing the same bellhousing, same basic layout. and the timing chain setup is very similar to the one used on the EZs. yea...it's only a matter of time before they make some serious changes. yea, framed windows......no more #@$%ing wind noise! but they're still subaru at heart. still interchangeable parts, still the same wonderful symmetrical AWD.
- 70 replies
- Historic
- Older
- Generation
- New
Tagged with:
all the current USDM subarus still use EJ-series engines (or EZs....which are very similar). and all the info I've seen about the new Toybaru coupe looks like it's still got an EJ engine and suspension very closely based on the current impreza's. still VERY similar to the 1989 Legacies.
- 70 replies
- Historic
- Older
- Generation
- New
Tagged with:
I cant keep up
yea, my wagon is the same way. every spring I work on a few cosmetic rust spots, and they hold up great all summer. drive the wagon one day in the salty roads....and they're all back.
I'm bout to put a round into this thing!!!!
one of my 200SX rears is the same way. ebrake doesn't work, and piston doesn't thread back in. so I'm guessing the piston is stripped. if you find a way around it, let me know. I tried some pressure from a c-clamp AND rotating it. still no luck.
official build thread.........this is monstaru2
this project excites me :slobber:
Converting 3.54 SVX lsd to 3.9 or 4.11?
AFAIK, an SVX diff carrier is identical to a t-leg VLSD. EXCEPT it's smaller to accommodate the taller gear ratio. the local yard here in Duluth has 3 SVXs, and 2 t-legs. all 3 SVXs have the rear diff, neither of the tlegs do. having not compared them, I'm not sure. BUT, having seen both, there's a possibility that tleg stubs might work with an SVX carrier, as they look to be very similar splines.
EJ Swap ?'s
meh, I haven't seen kennedy's manual. but from the info on the site, it sounds like it's just a glorified FSM engine electrical diagram. my write-up (about time for a revision....), '90-'94 legacy (ideal donor) engine wiring FSM pages, and some EA82 FSM pdfs linked here: http://www.numbchuxconversions.com/downloads.htm http://www.sjrlift.com is the place to go for adapter plates. wiring harness and flywheel both can be done yourself if you want, or you could pay to have them modified. yes, buy a whole donor car. first gen legacies/early imprezas can be had for cheap. then you know more about the condition/history of the engine, and you know you have everything you'll need (I pieced together a swap....and wound up making a last-minute junkyard run for an ignitor....DOH. thank goodness the local yard had one!)
worst post ever. since RX and tleg diffs are so easy to find and a dime a dozen, why don't you just mail me a few. also, I've done a couple of them, takes more than 10 minutes. even with the right tools. I, too, will be trying this in the spring. since my XT6 is a 3.7, I have to find a donor that's that or taller, which means SVX is the only EJ LSD that will work. I also know a guy parting out an SVX and will be trading my wiring labor for the diff and a few other parts. I've got an extra set of XT6 axles, and the SVX axles. I'm thinking there might be a set of rockford conversion races involved, but we'll see.
EJ swap under way
well, my 92 will look a little different.... I had to experiment to find the high-pressure line on the '86. jumpered the pump to come on, and had a buddy watch to see where it came out (IIRC it was the one down on the frame rail). that goes in the driver's side fuel rail on the EJ22 (don't forget a good FI-grade filter, my ej22 came with one, so that was easy). than the line fro the passenger side fuel rail and pressure regulator goes to the other line with decent hose clamps. and the third is the vent, and should be hooked up to the carbon canister.
