XSNRG
Everything posted by XSNRG
Depends on the year of the car. In '87 all Full Time cars were 5 speeds. In '88 all Full Timers were GL-10's (5 speed standard or 4EAT optional).* In '89 in could be either. The Full Time GL came standard with a 4EAT (Full Time 5 speed not available in the GL) In the GL-10 it (4EAT) was available as a option (5speed standard). As a side note, all '90 Loyale Turbo Full Time 4wd cars had the 4EAT, '89 was the last year for the Full Time 5 speed in the EA82. * Except RX. This information taken directly from the factory sales brochures, these list standard and optional features, exceptions are possible.
Welcome back. Yes, I would like some parts too. I have a list on your friends thread.
finally a post on this other motor im building
XSNRG replied to scrapdaddytatum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I like what I hear:brow: -
OMG theres JDM stuff for our cars
XSNRG replied to JWX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very informative Rob! I looked very carefully at the pictures and didn't see a '83 Safari Rally RX:boohoo: -
Sign me up for a '83 RX with this! http://ultimatesubaru.org/80s/projectrudy/spengine.jpg -
What 4WD station wagon for ~$3,500,00?
XSNRG replied to jdub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How many miles on the '87? Those are generally good cars once you get things sorted out. I've been looking at Legacy's for 2 years now and I really want one too. I'm pretty sure that if you find one for $2,500 it will be a car that needs stuff done on it. The Legs I've seen in the $2,500 to $3,500 range are usually well used, probably not any better than your '87. (A lot of opinion and speculation!) To get a good, low mileage, well maintained legacy in good shape, you will need to spend more. Average price on Autotrader for a '92 to '95 leg is $5,100. -
anyone have an IAC for a loyale they wanna sell?
XSNRG replied to naz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I may have one but don't know what it is. Could you tell me what IAC stands for, where it is located and what it looks like? -
New to the Board w/questions
XSNRG replied to Soobadooba's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Me too! -
Nope the 85 RX didn't have a auto or air suspension, sounds like a sticker job. Check for a LSD just for the heck of it... get the VIN if possible...
On a lighter note, Subaru related
XSNRG replied to ezapar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Never met anybody in a Soobie I didn't like:D -
RallyX awards banquet
XSNRG replied to bajavwnsoobnut's topic in Meet n' Greet. Your USMB Welcome Center
Jason, did you grab mine by chance? -
getting rusty clutch off old motor
XSNRG replied to PoorManzImpreza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There are two or three little aligning pins. Sometimes the pressure plate get stuck on them. You should be able to see them coming through the pressure plate near the outer edge. they are about 1/8" in diameter. If you can gently pry under the pressure plate near each one, working a little at a time, it should come off. You could spray a little penatrant directly on the alignment pins too. Good Luck! -
So what's the skinny on black RX's?
XSNRG replied to TROGDOR!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think the all white was even a '87.5 release. I have a Subaru Brochure that only has the RX 3 door and the XT including the FT turbo and it says "1987 1/2 XT and RX 3-Door Coupe" on the cover. I have a '87 RX sedan that is Mica Red and so I'm thinking the white sedans may have been released mid year with the debut of the coupes (also white) or colors were a option on sedans. I've seen '85 and '86 RX sedans in a number of different colors. I would sure like a black one.... -
15x6 and 15x7 4x140s for $60 to $70 each.
XSNRG replied to Dante's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep, that looks like a good deal for brand new custon rims, powder coated. I'm sure you could get a choice of centers and any offset. I like the pugs but it's nice to have other options! -
Installing 4WD transmission on a EA82 Leone
XSNRG replied to AlpineRaven's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hello, Several here on the board have done the FWD/4WD conversion, not sure if there is a write up. I'm sure they can give you insight. Definately easier to start with a 4WD, then you can put your time and energy into other mods, not to mention the downtime. I'm pretty sure you will need the 4WD flywheel and clutch and possibly the trans crossmember. Also the carrier bearing will need a mount and there are some of the mounting bolts in the rear area that will need to be drilled through the frame/unibody. If you can get a LSD, it is definately worth installing. Especially if your in loose dirt/sand, muddy or steep rough conditions. Really anytime off road it's a advantage. It can always be added later too, after the 4WD conversion, they are easy to bolt in. Good luck and keep us posted with your progress. -
1988 Turbo Maf sensor adjust. screw...
XSNRG replied to whiplash-smile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I haven't looked at mine. -
yet another "which is best" thread
XSNRG replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For cruising at 90 for hours on end you'll need the 4EAT. The RPM's associated with a 5 speed trans at that speed are probably not favorable for long distances. You can find those trannys in 89 turbo cars and 90 Loyale turbos. Also available in the XT, XT-6, Lagacy, Impreza. I was really happy with my '90 Loyale turbo wagon. It would cruise at 80MPH @ 3,000RPM, the 5 speed does 3,000RPM around 65MPH. I cruised that car loaded with gear and 5 people from the middle of Montana to Washington at 85/90 for 15 hours straight, just stopping for gas. -
Going to an auction Saturday :)
XSNRG replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mick, did you bid on anything? Car? Wheels? Did the Soobies sell? -
Andy, I have a FSM supp. that has the procedure for that, looks real easy, let me know if you need it. All you need is a new seal and a dial inch pounds torque wrench. This can be done in the car.
Pictures of my new Project Car...
XSNRG replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bummer. I just threw a '79 away. I didn't think I'd need any running gear, all I saved was the grille and the woodgrain dash. I'll see if the guy still has it. -
XT/RX/GL10 frankenwagon LIVES AGAIN!!
XSNRG replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cooool Andy:headbang: When you get done, maybe a spider swap write up is in order? That's something I would like to see! Pics when you get a chance.
