Everything posted by GLCraig
Anyone run with-out resistor pack?
running without the resistor pack can fry the ECU
SOA Gasket Q
The gaskets from SOA are cork and they should be replaced when you remove the valve covers because the usually tear. They are not that expensive, retail is only $15.90 for a pair. The grommets are AKA seal washer SOA 812764110 and retail for 5.68 for a set of four. They are the washer that seal the bolt holes in the valve cover. These last for 2 or 3 valve adjustment intervals.
trans swap
your 79 wagon will have a EA71 engine which has a different bellhousing then the EA81 & EA82.
Spectacular emissions test failure
GLCraig replied to Lesbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey do a tailpipe test with OBDII vehicles in WA, that's a bit different. Anyway the thermostat and O2 sensor are possibilties. A couple of others are the thermosensor for the ECU of maybe some dirty injectors. For reference my 94 legacy had 13 PPM of HC at 2500rpm, the last time It got tested.
Robin SUBARU Vs. Honda
I've seen them in some cheap junk too but I've also seen them on some high end stuff. Snapper uses them for their top of the line comercial walk-behind mowers which sells for about $300-$400 more then the same mower with a brigs.
Differential bucks
GLCraig replied to singsbass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm guessing that you have an automatic transmission and the symptoms described a case of torque bind. Since there are a couple of different causes of this, I couldn't give you an estimate on what it would cost to fix it.
Broke rear upper strut mount
Remove the assembly and see if the nut that should be at the end of the strut rod is still there or just loose.
EA81 w/ dual carb set up
I might be interested in the longblock.
May 15th Rallyx #2 in Oregon
results are in http://www.oregonrally.com/content/results/rallyx/May_RX.pdf
EA 82 Overhaul
The o-rings that go between the heads and the camtowers a very prone to leaking. Also the head gaskets will sometimes leak oil but seal the water jackets and hold compression. If you plan on doing a complete reseal, you might as well pull the engine, everything but the rear main can be done without pulling it but it makes it a lot easier if you do. You should also think about replacing the timing belts while you are at it too.
Loud Brakes....
GLCraig replied to ScoobyRu93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the slot down the middle of the pad -- if your pads have one -- for dust build-up.
help!! need ea81 head today in portland.
Why didn't you call Mt. Tech? They're open on Saturday.
Alternator high voltage
That is a definite possibility
Bring your raincoats, the weather guys said there could be 0.60" to 1.00"+ of rain overnight Saturday and through the day on Sunday.
EVO 8 injectors
check to see if those injectors have roughly the same impedence as the stock ones. There's no need to fry your ECU as part of the R&D.
Fuel pump probs--89 RX......FIXED w/update
Try replacing the relay, sometimes when they get flaky you can get a 12v reading but once there is a load applied it could be a lot less.
Anyone else familiar with the 1400's?
Send a PM to bajavwnsoob he maybe able to answer your questions.
local stations have it a bit different Thrus sunny 70's Friday sunny 70's Sat rain sun rain
- hahahahaha*gasp*hahahaha!
ea81 fuel filters
It depends on what year EA81 you have. 80&81 only had 1 filter 82 and later had 2. 80&81 are in the engine compartment near the pump. 82 and later, there's one in the engine compartment above the brake booster and the other is under the car near the back right tire, next to the fuel pump.
how do I get in that darn place??
it's been years since I had to do this but if I remember right you need to pull out the cluster.
$6K difference Outback to Legacy?????
GLCraig replied to Spokane-Pete's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe stickers and emblems that say Outback.
The long term weather forcast says it't going to rain that day.
RX spring question for spring geeks or engineers...
Okay let's see if I can explain this without pulling out one of those big money text books that are collecting dust at the moment. A springs resistance is rated in units of travel per force applied IE lbs/in or KN/mm. So let's look at an example. Let's say that you have a 24in long spring that's rated at 100 lbs/in and you compress it 6 inches, the spring is now 18in long and it's exerting 600 lbs of force. Not let's say you have cut 2 inches from that spring so it's now 22in long and you compress it again to 18in. Since you only compressed it 4 inches this time, it will only exert 400 lbs of force. Note: This is assuming the spring is wound at a uniform pitch.
Didn't you just spend some $$$ on a roll cage for your legacy?
