10
Everything posted by ivans imports
Its always the head gasket 250 headgaskets later have seen every kind of diagnosis " its not the headgasket " over and over its always the headgasket. Any bubbles in rad is headgasket the comp slips past the fire ring and putts 180 psi up agianst 12 psi putting combustion into rad over preshureing rad and pushes all coolant into overflow. no piont doing anything but the headgaskets. Have had this senario 3 times this week 98 outback 01 outback and 96 out back all headgaskets.
I tripped over this . EA81 upgrade to SPFI
ivans imports replied to nipper's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I converted my 81 brat to tbi it loves it took a day to do 15 % more power and way better runability has been tbi for 10 years no problems -
Thats ok they all are loose there have seen up to 1/2 inch of play no problems is floating shaft
- 45 replies
- transmission
- differentials
(and 1 more)
Tagged with:
As long as its not dry also should be going up and down at a good rate do not go slow is important to get a good xrosshatch
Can go in stoped but must come out spinning or drag marks
No power on pass side cyls? HELP!
ivans imports replied to CarpeNoctem's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If hlas were removed they pump up to max height so when reinstalled the valves dont close is very commen for it to only run on 2 till it warms up and lifters can bleed down and valves close again have had it take 30 min or more. when i have lifters out i pump them down so the have to addjust is better ticking than missing. I bett you just dident give it enuff time or timing is out -
Should be crome molly
Check clamps on intake feul lines when your done doing the head gaskets
- 13 replies
- Overheating
- thermostat
(and 6 more)
Tagged with:
I use a ball hone on slow speed lubed with 10-30 oil is very important to go up and down consistantly and smoothly and try not to stay at top of cly to mutch as they wear tapered so more honing at bottom of cly than top. I also putt a old gasket on top of block to protect it from scraches
#1 dose it have a working heat riser ? mabee freezing up carb also have you changed the rear feul fillter and given it some gasline antifreeze in case of water in feul. Clasic ea81 crbed car is carb freezeup on cold wet days give it five min of sitting and runs fine ? or will just not go anytime ?
- 5 replies
- engine problems
- missing
(and 5 more)
Tagged with:
HELP!..2.2 sohc and 2.5 dohc swapping engine parts and motor
ivans imports replied to Rrich681's topic in Subaru Retrofitting
If the crank sprocket is different so is cam sprocket how many bumps on cam sprocket ? and how many on crank sprocket that came of car -
They made brats in 86 realy anyway check the diss shaft for play and check the mas air flow door moves freely and no air leaks anywere inline with intake plumbing and check for water or dirt in feul fill also have seen cars in this era plug the PU screen in the tank and not get enuff feul
- 5 replies
- engine problems
- missing
(and 5 more)
Tagged with:
Use sprokets from car BUT the twin cam 2.5 has plastic cam gear this will not work on 2.2 you may have to locate a 2.2 cam gear to match the car. How many bumps on your cam sproket ? -
A'm biulding a offroad outback sport right now gets the whole outback lift / struts cutt the rear body off flush with floor added twinn E brake levers skid plates and now have a killer offroad sport sitts realy high. Is a realy fun car and yes the outback sport came with 2.2 witch is a realy good thing !
Main shaft berring is gone alowing the awd gears to touch eachother on back end of trans
- 45 replies
- transmission
- differentials
(and 1 more)
Tagged with:
