5
Everything posted by Dee2
What is voltage at the battery ? Have you checked the fusible links for corrosion ?
You say it won't start but you don't tell us anything about what is happening when you try to start. --does it crank ? --do you have spark ? --did you check all the fuses ? --did you check anything else ?
You have to call the dealership and ask them to look in the "old database".
These statements lead me to think your fuel pump is going out. Intermittent starting, rough running, runs with starter fluid are all signs of a failing fuel pump or a clogged fuel system. This sounds like a clogged exhaust system. You've got more than one problem going on which makes it hard to diagnose. I would check the exhaust system from front to back to make sure it is clear before doing anything else.
Ea82 ignition switches short
Dee2 replied to Olyroller83GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would expect to see a blown fuse before something melts. Are there fuses that are bypassed ? -
Someone may have a spare. Also check with any local boneyards. Some people have reported using a fuel pump from an old F150 pickup. You'll need to search this website for more info. Good luck
codes are here http://www.4bc.org/vanagon/codes.html
Drivers Side TB Snapped Tonight
Dee2 replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's a couple of articles that may help -
That's a lot of noises. Some could be internal and some could be external, hard to say with so many. INTERNAL Check the timing belts again to make sure they are installed correctly. Check the spark plug wires to make sure the firing order is correct. Possible Damage You may have broken piston rod EXTERNAL Check the motor mount bolts. Check the exhaust bolts.
cold start issue HORRIBLE cold starts, SPFI 88 GL Dual Range
Dee2 replied to YnotDIY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most of these old cars have power problems. You may benefit from doing a compression and vacuum test on that engine. -
I don't think a grounding problem would go away when the car warms up. With so many codes it seems impossible to know what's happening. I would clear all codes and start over. if you keep getting all codes I would suspect the ECU/ECU connections. Otherwise see which codes persist and go from there. -
1992 Loyale cranks but no spark
Dee2 replied to Griffon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As Dave said, make sure you have power going into the coil then check for power coming out of the coil. -
1991 XT6 won’t idle, runs rough
Dee2 replied to toomanynooks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It might be starving for fuel or have a clogged fuel filter or a failing fuel pump. Check the fuel pressure to see if it meets spec. -
Also need to check the air filter, it probably sucked up a lot of oil spray too.
I had the oil changed on my car one time and when I got home I had oil all over the under side of my hood. Turned out the oil filter was not correctly tightened and was making a mess. Check the easy things first.
Loyale repack front wheel bearings
Dee2 replied to rickyhils's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As an alternative, if OEM are not available, you might want to see if Altrom seals are available from NAPA . They are OEM quality . -
Loyale RX /RS Front Spoiler/Lip Plug 3D Print
Dee2 replied to jdmleggy97's topic in Old Gen.: 80's GL/DL/XT/Loyales...
very nice! -
Sounds like a transmission problem.
Almost no stopping power 87 GL
Dee2 replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You likely have some air in the lines or in the master cylinder. -Check all brakes for mechanical wear or damaged parts. -Check all lines for any leaks -try bleeding the lines -try bleeding the master cylinder. If these don't fix the problem you may have a worn master cylinder to replace. -
1986 Subaru GL Flapping Noise. Struts?
Dee2 replied to 3crows's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Noises can be tricky and sound like they're coming from one area and actually be from a different place. Flapping noise is often a belt or other rubber item. I would check all belts to make sure they are not failing. Also check boots on axles for any tears or grease splatters from the boots which indicates a break.
