Everything posted by Turbone
Somebody Stole My Soob!!!
Well, it sounds like you have a good start on it. There has to be a way to find out where he took the cars. Is there a local place that takes scrap? Maybe they can tell the cops that he brought the cars in. And for all you folks that want to do bodily harm to the perp, I just want to say that this creep needs to go to jail. Where he can end up being Bubba's Beeotch
What did I do?
It sounds more like the DOJ came off the stub axle. Maybe there was no pin in it? It needs to be lined back up with the pin hole and pushed back on. Then replace the pin, and Lower ball joint (I assume), and you should be good to go.
Apology
Theres no need to walk around on egg shells here. Lots of us have made "Faux pas" (Fr.), and if we dont step on any toes its ok :cool: Intentional stabs and pokes usually are between people that know each other well enough to not cause hurt feelings Rants about certain things are exceptable I think, but it depends upon the topic. Eh, just my .000002
SWEET JUNKYARD FIND....i think ( 6 pictures )
Yea, see if you can get a salvage title for it. Please try and keep the car complete and not part it out
got stuck on N-405 today
Geeze, some people have all the luck J/K Glad you got it fixed.
tire question
You should be ok, if you stay out of 4wd. I know the diff isnt much, but why take a chance?
Somebody grab the digidash out of that sucker! Is the body all beat up?
Wife's Newer Vehicle (pics added)
Uhh, Gen 1 OBW?
What Should I Do With This?
Wow, what a coincidence :cool: It also has a blown HG, cracked dash. But its already got a 5spd.
Basically, its just a labor intensive job. If you have done it before its not too bad. And are you thinking of the same XT I am?
Turbine Wheels!!!
Thanks Brian. Well, those are ........different Good luck finding another one of those .
Turbine Wheels!!!
Yea, I looked in your album and its not there. Can you give us a better link?
The mysterious new "fix" for HG
Turbone replied to BlueSoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm, never heard of it yet. But its been known for a long time by only a few people that you can use Sodium Silicate to seal HG leaks. You can get it a good Pharmacy, or look around on-line for chemistry stuff. I wonder if this is what they are using?
problems shifting while running
Its most likely you have some junk in the linkage. Get under the car and check to see if theres a rock or stick or other stuff in the tranny tunnel.
Being like Cartman (Vehicle Weight)
Hmmm, I can weigh my Hatch tomorrow. Theres a scale about a mile away.
Obvious post of the day (fuel Pressure)
I think Qman had some info on this, maybe if we can keep the thread on the top he will see it and respond. Or you could just email him :cool:
Has anyone been wanting to see inside one of these?
In hoping not to sound to stupid here, but if you had a locker front end, how would you be able to steer? I know what happens to my rear end with the welded diff when I turn, so I can imagine what a locked front end would be like
So is my car really worth this?
Timing belts, cam seals, main seal, water pump, oil pump kit. That should do it for the front. Might think about the rear main seal. Intake manifold gaskets. I guess you should just get the full gasket set and go from there
Is my weber a diesel?
Ditto's here on the Weber dieseling. Havent bothered yet to remedy it tho. I will try the timing and idle speed, and maybe flush the top end. Dave, sorry, but your suggestion is not a very penny wise idea right now. I believe the cost of high octane gas is over $2 a gallon in most places now And the Regular isnt to far behind
gas tank questions(guts?)
Theres a screen on th end of a tube or hose. The manual doesnt specify or show it. You might have blown the screen off, or whatever was blocking the end. Is it still clogged after blowing air in it? The fuel seperator does just that.
The fun begins(update)
Thats a little guy, but it does fit nicely.
The beer glasses for the WCSubaruS6 WILL hold at least a 12 oz beer
I volunteer to be the bouncer And the DD :cool:
EA82 firing order
I think you were right the first time with the engine type. So far I know of no one that has been pushing a EA81T at 18 to 22lbs of boost. That sucker would go thru the roof 14 to 16lbs is even pushing it. If you have plastic covers on the front of the motor, its a EA82T. Its a OHC with belts running the cams.
ignition timing procedure
The disty could be a tooth off. Or maybe you have the wires on the disty wrong? With the cap off, the rotor should be pointing at 11 o' clock (TDC). Rotation is counterclockwise, and the cylinders are numbered; 3 4 1 2 And the firing order is 1,3,4,2 Check this and report back, eh?
Getting ready for the lift
Northguy, sorry to hear about the ordeal. I think UPS is even worse. They may get it there at the time they said it would be, but its to the wrong addy Brian, any Soob you saw in Ak when you were in school is long gone, eaten by the rust bunnies.
