Everything posted by Turbone
Turbo transplant questions
If the 84 wasnt set up from the factory as a turbo, then no...not really. It needs to have MPFI, a bigger fuel pump and lines, ECU and harness. Also will need a turbo cross-member, so the up pipe will clear.
Lightest EJ based soobie for wheeler ???
Try and find a Brighton 2dr model. They have the basic package, no options. Crank windows, no AC, etc.
Vehicle Selection
This is not a good choice for a offroader. While most will say a turbo isnt desirable for offroad use, this one in particular more so. Even if you didnt take it offroad, the engine will give you lots of headaches. Plus all the electrical goodies in the car will play havoc with you if things get wet, which is highly likely living in W. WA. Also, the suspension will need to be removed and swapped out with standard stuff (maybe a lift too). And the AT will suck for offroad use. It should have a 5spd dual range for offroad use.
Got an 88 RX
Yeah, that was Bills RX that self destructed, not mine. Altho mine has a habit of destroying engines
Which K&N air filter for 86 RX Turbo ?
I've used the 33-2010 in my RX for a couple of years without issues. And if you drill 2in holes or cutout the bottom of the airbox, you get plenty of air. And some neato sounds too.
witch is best ea81T or ea82T
Do you have any idea how much a engine like that cost? Just the rings/piston for that are more than I paid for my RX. Personally, if I had the $ for something like that, it sure wouldnt be going into a 25yr old Subaru.
I'm a little worried about what the rest is going to look like now
White RX w/ 5-lug conversion in Kirkland, WA
Thats clear over on the other side of the country
Leave a note on it next time, tell them about the USMB.
WJM - RX Turbo
This one? http://boise.craigslist.org/cto/1593970056.html I was sent pics of it and it didnt look that bad.
Went Ice Fishing in the Suby
Bigger tires help with flotation. Some extra lift helps also
Official 'Christening' of "Waterwagon 3"
Yup, not much has changed in all these years......except for the wagons :-p
a pillar gauge pods
Mine is for a 02 WRX. Had to trim the bottom to make it fit, but the top is fine.
What do you do to keep your shop clean?
I dont need to say anything here....my rep and others can attest to that
EA82T head issues
I think he meant ARP head bolts are expensive.
WJM - RX Turbo
http://www.ultimatesubaru.org/forum/showthread.php?t=108543
Suby Wagon Wood Truck, this could be the Suby offroad picture of the year
Its a 5yr old post.........it evaporated.
SVX wheels on 78 toyota 1/2 ton?
Offset is 55 and the bolt pattern is the same. But will a 16" wheel and tire fit on your Toyota?
official build thread.........this is monstaru2
I did that once...........................and threw the pieces in a scrap bin
Green
Sounds like you belong on Nasioc :-\
- Gears
Not getting a reading for oil pressure
I just thought of something....we need to check all the grounds, make sure we got them all connected.
Some progress....
I long for the boost love
http://www.ultimatesubaru.org/forum/showpost.php?p=899395&postcount=758 More than I've seen from you in a while
Oh, it is now I started mine on Fri.
