  • Replies 7.4k
  • Views 1.2m
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • wood floor
Posted Images
Even better! Did all that damage with my fingers. I have some POR-15 on the way.
http--,,--//P9190617_zpsn3zhbbkw.jpg
Today was a busy day. First I bed lined the bed. After that I modified a GL wagon bumper to fit her. Then I started on my body work
Invested $20 into my sedan.   Found a front spoiler at the dump = $0   Got a set of fog lights at harbor freight for $15
And $5 on a can of  rattle can spray to freshen up the rims.
had a low beam bulb go out on the WRX, installed a pair of GE Nighthawk bulbs. fairly easy, right side - just 2 bolts to remove the intake funnel. Left side, one clip to shift the wiper fluid filler tube - it was tight, if I had sausage fingers, probably have to remove the battery.
Edited by 1 Lucky Texan
  • 3 weeks later...
Been busy. Gutted the interior of the new wagon, so I can get it cleaned better & see if the stains come out.
Removed the radiator & found out that the seal on the drain port was broken. hopefully, this was the reason there was no coolant and not because of an engine issue.
I saved my Subie  :D  :)  :D  :) .
My WRX had a blown head gasket (internal; coolant in combustion chamber), and I had to make a choice.
I decided to fix her, and I am so glad I did! She's no longer going to be my DD, as I have a an XV crosstrek now, but I'm planning on some awesome joy rides on the weekends, and absolutely can't wait!
Took her for a drive this morning and it felt so good. It was confirmation that I did the right thing :)
Edited by belacane
  • 3 weeks later...
Fried the center diff on my impreza woods runner, need to weld that up now, gonna do the rear while I'm at it as well.oNGxdW0.jpg
  • 2 weeks later...
  • 2 weeks later...
searched and searched in here for the post on LED conversion for twin light EA81 Brumby.
No findy
Had a moment to try the 3 rows of LED in a quad light size on the outer low beam. Needed to be rigged to work not just plugnplay. I considered too btright and scattered to trust oncoming drivers not to be blinded [but given the test drive later - others LED lights from factory have no regard !)
These work nice in the high beam inner position - plug and play. Just need longer M4 bolts 16mm would do, I got 20mm- [not tapered, so not calling them screws! ]
Yes, LED highbeam light is better - and different .....bit like flouro light different to incandescant in houses.
I would love to try the low beams that run the bottom row and centre LED of middle row once wired correctly and drive towards my car on dark nights, wet dark nights to experience just what they do to oncoming drivers eye !
Would lve to see road hazards before i feel them :(
sourced from China ebay seller
also, as I had to release male terminals from the plug, zapped something :( lost bright low beam when returned to std lights, got that typical low yellow glow often seen in old datsun/Nissans of the 80's. Found i blew the fuse panel fuse for that light.
i could not just rewire led to get low and high work while inner highbeam light connected. To dod would need the wiring mod with extra relays
Edited by jono
Dear Jono,
... LED conversion for twin light EA81 Brumby ... These work nice in the high beam inner position - plug and play. Just need longer M4 bolts 16mm would do, I got 20mm ... LED highbeam light is better - and different ...
How could you post such information regarding something very Visual, without adding Photos?
Please, share some with Us, I'll like to see your Brumby with the LED Headlights' setup,
also it would be interesting to see how they illuminates the Road.
Kind Regards.
  • 4 weeks later...
Got my recaro seats installed, finally. Unfortunately they sit too high for my liking. I should of taken more off of the base but i wanted to keep a brace that went across them. Ahh well, they are comfy. Also got tyres on my mag wheels, finally.
Pictures
http://puu.sh/lSNpC/a353944253.jpg
http://puu.sh/lSNsy/609a62e4af.jpg
http://puu.sh/lSNuR/264472c6f3.jpg
http://puu.sh/lSNw4/40d0b7a38c.jpg
http://puu.sh/lSNwV/cce2b44003.jpg
http://puu.sh/lSNyK/42b0fda8cb.jpg
http://puu.sh/lSNz8/be78227dfd.jpg
Haven't done   it yet but still thinking about engine / driveline upgrade for Brat /Brumby
Phase 1 SOHC N/A EJ22 for simplicity reliabilty non interference and mid range.
matched to an 86/88 RX driveline ie 5MT AWD D/R centre locking diff with rear LSD (unfortunately rare as hens teeth)
but probably won't happen as cost + components difficult too source. etc.
So  probably end up just rebuilding its EA81 and leaving it original. as motor tired using a quart every 600 miles (still runs ok :-) but  hungry
Dreams  are free :P
Edited by subnz
^ That actually reminds me of the other thing I did recently haha, bought an rx driveline for future use in my wagon. 5speed dual range diff lock, rear lsd.
Cost a fair bit, but hey, they're still printing money.
http://puu.sh/lTJxq/3edfbf53e8.jpg
http://puu.sh/lTJyZ/75db7b160b.jpg
http://puu.sh/lTJyq/dc4e43345f.jpg
wow  its all there, even gear lever surround with diff lock switch -  might have to come and steal it :P
Yeah haha, only things I am missing are the two vacuum solenoids, which isn't too much of an issue.
Made this work, wasnt to bad a install. Had to trim down the rad cover is all.
Also, a recent pic...
That RX!!!!!!!  :wub:
What Have I Done to my Soobie lately?
Mistakenly, I Cracked the Windshield!  :banghead:
I opened the Hood to check for a Loose battery post connection, without noticing that my Little Daughter, left a small Plastic toy hiding on the opening at the Windshield's base, behind the Hood; so, when I opened the Hood, I heard a loud "CRACK!" sound, and saw that the Hood pressed the plastic toy against the Windshield's base...
Kind Regards.
I've done that before with a wrench or something, felt really stupid. I did the same thing to my laptop screen last year, closed it with crap on the keyboard  :banghead:
At least replacing that is cheaper and easier than a windshield...
Yes, I really felt Stupid doing that ... :( ...
Now I'll search for another windshield and the Chromed plastic trims' Corners for it,
because I lost the one on the lower corner of the Driver's side.
Kind Regards.
The windshield was immaculate prior to this, but such things happens.
Now, how to find the Trim's Chromed Corners...
Kind Regards.
Nuts. I did something sort of like that years ago. Put a 3/4" id 10 foot piece of pvc Condit diagonally across inside my wagon. Closed the back, No problem. Another trip, I buy a 2" id 10 foot piece. It doesn't bend as Much as the 3/4... looked like it fit and all, but when I closed the back, I cracked the windshield.
