87
Everything posted by DaveT
Be very wary about running it with any coolant leak. A 30 year old turbo is going to be a challenge to maintain. Finding anyone who knows them well who is in the repair business is going to be tricky also. I think there are a few turbo guys on here. I'm running a non turbo spfi 87 and a 93,, and intend to for a long while, but I do all my own repairs, and can even make parts.
It's in the casting of the head also. Oddly, not in the intake passage.
rattling exhaust shields fix tip
DaveT replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Copper is good for somewhere around double that. -
Gas Coming from motor into exhaust....93 Loyale..
DaveT replied to DC493's topic in Old Gen.: 80's GL/DL/XT/Loyales...
T a pressure gauge into the fuel supply line, after the filter under the hood. If the fuel pump isn't running, there would be no pressure, or only a little stored. There is no path for fuel to get into the engine / out the exhaust other than through the throttle body. -
want wire connectors like in loom
Try Waytek wire. I never looked for those, but they have a LOT of other low V & automotive type stuff. -
Never had that. 1st thing I think of is some how flooding the intake at the throttle body. Maybe no spark? What had to be disconnected to do the swap? -
I've never seen rtv melt once cured. Char from too high heat, yes. Dissolved by contact with fuel, yes. -
I always fixed the rattles with a cutoff wheel. Seems like it's not going to burst into flame, but it might smoulder until enough of it is gone. -
Another HG thread with part #'s
DaveT replied to wagons's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't know about a blue dot. EA82 head gaskets only fit one way. Look at the 2 alignment pins, and the bolt holes and the oil return passages. Wrong way. and more than one of these won't line up. -
keep a close watch on that.. Exhaust pipe temp can get pretty close if not over the operating temp of silicon. -
Something wrong here. Ea82 red line is at 6000? Mine won't go faster than that anyway, they just stop increasing rpm.
Timing belt pulleys, tensioners, etc.
DaveT replied to 89XT6's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The o rings between the heads and the cam towers are metal enforced. I have gotten them from a dealer. They may also be available from industrial supply houses, but you have to know the sizes and all that. Don't use plain orings. -
Loyale rear wheel bearing
DaveT replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
On the ones I did, with the special socket I couldn't get enough torque without it popping out of the stickier ones. I ground a special tool for my air hammer which made short work of the stickier ones, and didn't destroy the nut to where I couldn't use it.. -
There are a total of 7 hoses involved with the cooling system. A few of them can leak on top of the block. Unless you know they are new, replace all of them. Be sure to clean the nipples , they typically have rust and won't seal. I have found that plumber's silicon grease makes later disassembly much easier. Once the new hoses are on, and you have followed the procedure to remove most of the air, watch the coolant level closely. You may have an intake gasket leak - those can go either into the intake or out onto the block. Head gaskets can develop seeps to the outside. I have usually seen this after an overheat while low on coolant. This also can lead to blown head gaskets. Smelling hot coolant usually means a small leak where it hits something hot. Intake leak has to get very bad before smoke gets obvious. Coolant in the oil doesn't usually happen until the head gaskets are VERY well blown.
Not sure of this help - I had a similar problem with my 90 loyale, non turbo. The alternator belt was a weird size. Normal ones, one was just long enough to not get tight, next size shorter wouldn't get over the sheaves. I found that I could file the alternator bracket adjuster slot a bit longer, so it would allow the shorter belt to be installed. In my case there was no room to go the other direction, as the alternator would have hit the battery.
- 11 replies
- Alternator belt
- Accessory belt
(and 3 more)
Tagged with:
Freshly rebuilt EA82...not so fresh! driving me nuts
DaveT replied to Jugizmo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've run a couple engines without thermostats temporarily. I did not find that to be what happens. The engine never gets to operating temperature. While the coolant isn't in the radiator long, it is not in the engine long either, thus moving heat out quicker. -
Is it possible to swap the transfer case on a MT?
DaveT replied to pgerbz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1st thing to do is look up the final drive gear ratios of both.- 7 replies
- transmission
- dual range
(and 3 more)
Tagged with:
Watch out for this exhaust problem
DaveT replied to zyewdall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I only had one do that, forgot what the cause of the muffler / tail pipe being out of position was, but it was due to something not correct about the end / angle of the tail pipe. -
I've had the intake leaks not show with a pressure test. You won't typically see water in the oil until the headgaskets are very well blown. All 7 hoses is a good idea.
- 11 replies
- coolant1.8
- gl
(and 1 more)
Tagged with:
There is a coolant passage at the base of the carb or throtitle body. A leak can occur there. Also, the intake manifold gaskets can do this. Use only oem for those. Watch the coolant level in both the radiator and the recovery tank like a hawk. You do not want to be low on coolant.
- 11 replies
- coolant1.8
- gl
(and 1 more)
Tagged with:
ea82 d/r gears moving out of place?
DaveT replied to Subinoobi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you saying the whole position of the shifter moves? Everything still works ok? In that case, I'd think transmission mounts might be bad. -
EA82 - no compression in one cylinder
DaveT replied to jasonkaye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Unless you have serious suspicion about the lower end, put the heads on it. I avoid the long down time problem by refurbishing a spare engine, then just do the swap on a weekend. -
The boots are pretty much the same. You have to disassemble the inner joint to get the outer boot on / off, as described above. Once everything is apart, clean thoroughly, re grease and assemble with new boots.
I did some off the car, one on. It will depend on what you have for a press. It was a lot easier to figure out how to do it off the car. I had spare arms to try things on before going after the car. -
Here is my web page write up: http://www.dynahoedave.co.nf/rearwheelbearing.html
