87
Everything posted by DaveT
Respect for the EA81 and performance mods!
DaveT replied to RAD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's like when I found a car slower than my 76 4WD wagon. A VW Rabbit Diesel. -
Our 01 Forester had the intermittent 0420 code. New O2 sensors had no effect. Turned out to be a small exhaust leak in the cat pipe. Any leak between the 2 O2 sensors would cause the code. Yes, it can be caused by other things as well. Failing cats is one for sure, as that is what the 2nd O2 sensor is there to do - verify operation of the cat.
If you get a thermostat, get OEM or high grade Stant. Other cheaper ones have been known to cause problems.
- 12 replies
- 1
- overheating
- over
(and 3 more)
Tagged with:
Depending on the geometry of the system on your car, opening the radiator cap indruduces air, which is why I don't check by opening the cap unless there is no coolant in the upper hose.
- 12 replies
- overheating
- over
(and 3 more)
Tagged with:
Check level of coolant : check the rover tank is filled to the line. Sharply squeeze the upper radiator hose. You should hear the giggle pin in the thermostat. You should feel water resisting the squeeze. You may hear air gurgle. If it feels or sounds like only air, that has to be dealt with. A normal good non leaking system should have no air at all, or maybe a tiny amount.
- 12 replies
- overheating
- over
(and 3 more)
Tagged with:
5 years is end of life for lead acid batteries, under ideal conditions. Sometimes they will continue to function beyond that, but a full test of capacity, and cca would show the degradation.
- 18 replies
- starting
- long crank
(and 2 more)
Tagged with:
88 GL Water Pump Replacement Questions...
DaveT replied to YnotDIY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Who make the best timing belts now? I'm not worried about the idlers, I have that covered.- 9 replies
- water pump
- sizing
(and 3 more)
Tagged with:
Project: Gallery of my Subaru
DaveT replied to 88SubieSnack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you have a part number for the kyb white bump stops? -
I think I found the same listings on partsgeek.. The picture you have above looks like the one listed for a 1.6L engine. If you have a 1.8L engine [EA82] then you want one the other ones. I have always run the 2 row turbo radiators in my GLs & Loyales. But those are not to be found any more. The brand I had happened to find that used to sell them was CSF, all metal.
84 brat automatic not shifting to 3rd
DaveT replied to rkbean's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A fsm will have diagrams for the vacuum lines. Also might be worth checking the diaphragm in the modulator. When it fails, atf is sucked up the vacuum line, and burned along with the fuel. -
Stock Subaru gl 1.8L carburetors
DaveT replied to Stephens243's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hitachi. Note, you will likely have more answers if you post in the older generation sub forum. -
Those are the lines for the automatic transmission cooler. If you don't have an automatic, just cap them with dust covers, and use it. Not a leak risk. I've never seen an aftermarket radiator without them.
I've never had to replace or rebuild an oil pump, just replace the seals. With proper maintainance, it should be ok. Yes, parts are going to be harder to find. I am expecting that. I have a lot of spare parts to keep my ea82s going for a long time. How practical it is to run 30 year old cars depends on your situation. Do you have space to store spare engines, driveline parts, etc.?
1988 GL 10 Turbo Wagon Ignition Removal
DaveT replied to CFTrunt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The wiring in GL and Loyale is quite long. Lots of connectors. The starter solenoid draws 20 plus amps. It doesn't take much drop for it to not be fully pulled in, thus the click no crank. The relay draws maybe 0.2 amp. And the short wires on the contact side ensure full battery voltage to the solenoid.- 17 replies
12.6 v is normal fully charged battery at rest. When you get the click, if the rest of the electric stuff stays on, and doesn't dim out significantly, the connections are probably ok. Relay, or another connection in the crank circuit can be intermittent. FSM will have all the details of switches fuses, connectors. All need to be checked. Intermittents are a pain to find.
The relay I used is a black plastic cube about 1" with a metal mounting tab, and 1/4" push on tabs for the connections. I bought it at NAPA. I mounted it using one of the bolts that hold the fuel filter bracket. One end of its coil connets to the wire that originally plugs onto the starter. Other end of the coil goes to gnd. Run a 12 awg wire from battery + to a fuse, then one of the contacts. Othe contact goes to back of starter.- 17 replies
Look for rhe engine electrical schematic. Find the alternator section. It might take a little tracing of lines, etc. To figure it out, but it should show what fuse is in the circuit. It should show what pins go where. On gemeral, 1 wire has to be going to the alternator light or indicator lights. One has to be fed power via the ignition switch. Those circuits have to be intact and functional for the alternator to work.
