45
Everything posted by carfreak85
Computer science or programming. These positions are in EXTREMELY high demand and they pay a crap load. If you want money for toys, this is the line of work to get into...
Might that place be Witchhunter?
Just use a rising rate adjustable fuel pressure regulator. Old Subarus run a low fuel pressure (36psi IIRC) where the industry standard for non-direct injection is like 43psi or something. By raising the fuel pressure your 185cc/min injectors will act more like 250cc or there abouts.
Question about EA81 Turbo Water Pump
carfreak85 replied to Non Culpa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Definitely go new vs. rebuilt if you can afford it. Dealership would be a great place to get a quality new part. -
Project Ramrod Spec C TWE Header Pics inside.
carfreak85 replied to beataru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Interested in selling the TWE header? -
4x140 to 5x100 bolt pattern adapters
carfreak85 replied to matts87glsedan's topic in Products for your Subaru
I am interested in more data on these. What material are you planning to make them out of? Obviously your prototypes are aluminum, but what grade? Any heat treating planned? You have 5,000km on them so far. Great! What is the maximum speed you have tested them to? Do you have any plans to do any V-max testing, or will there be a suggested ceiling? What sort of runouts numbers are you shooting for and will there be any balancing going on? Have you considered having holes machined to allow the OEM hub/adapter assembly to be unbolted from the upright as a unit? These are NOT criticisms of your planned product, I just want to be sure that these will be safe and durable. -
Interesting choice in intercoolers... From what I've read, the supersized TMICs are notorious for heat soak and are generally regarded as all show, no go parts. Might want to think about swapping back to the OEM part. http://forums.nasioc.com/forums/showthread.php?t=2126473&highlight=tmic Obviously this is your car and you can choose to do with it what you like, in fact I have debated making this post since your initial post, but finally decided to. Again, not intended to be critical, just some food for thought.
My new 1977 sport coupe
carfreak85 replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
Planning to flood the market, eh? Starting to look like my shed! That dash is AMAZING, btw, score of the century... So far... -
Rarest Old-School Subaru Part or Option?
carfreak85 replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Momo no longer manufactures the ea81 adapters. -
I have two sets of wheel adapters that I am never going to use if anyone is interested. one is 4x100 and the other is 4x114.3 I can send photos to whoever wants them.
Those with oil TEMP gauges...
carfreak85 replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
On my EA81T with the factory, thermo-controlled oil cooler, the Autometer oil temp gauge I have installed in the oil pan is usually pretty high. I think oil starts to break down around 260*F and my car is usually over that... Maybe the thermostat in the filter sandwich is stuck closed on my car? Anyway, 240*F in the winter is still darn hot. Keep an eye on it as the ambient temps start to creep up. Make that trip to Pasco in the summer and I'd be willing to bet you'll be over 260*F. -
Pull one of your side view mirrors or pull the door panel, look for wires. Alternatively, you could look for the connector behind the console, should be pretty easy, considering there is no console...
ea81t factory manual questions
carfreak85 replied to turbosubarubrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, but he is looking to use it on an EA81T. The 84 FSM does NOT, to the best of my memory, cover any EA81T-specific wiring diagrams. If he had a regular old carb'd wagon, yeah the standard FSM is all he needs. -
Those will be very helpful on most '84s and you will need them for the basic info on many operations. However, neither one will have a ton of info on EA81Ts. There are two supplements to look for, one for mechanical and one for electrical. Those are the manuals that really hold all the secrets. -
The window might not be working because they are not the correct switches. Additionally, at least on my wagon, the rear window switches afe auto up/down and have more wires than the regular ea81 power window switches.
Stop. Do not touch another bolt on that car until you have done some research. I am more that happy to help you if you run into any problems since I have done this swap before, but all the questions you've posted here are in the forums or the USRM. Do your due diligance, and come back after you have read everything on this topic. Twice. Then read them all again. Also, please check your spelling and grammer. It makes it easier to read and once you're out of school, you'll have no excuse when somone flames you for it. Holes, not "wholes".
Keep us updated on your progress, looks pretty good for a free car!
Harbor Freight tools to avoid or not expect much from
carfreak85 replied to idosubaru's topic in Shop Talk
Spent over $100 on a 5 gallon pail of Redline oil only to have my then-new HF pail pump fill the oil with metal shavings as I pumped it into a graduated cylinder. I HATE HF, tarps and other BS only. All tools/hard parts will be quality from now on... -
Another Jalopnik article
carfreak85 replied to Giant's topic in Historic Subaru Forum: 50's thru 70's
Neat review! Makes me want to get my '75 back on the road! -
Yeah, what Hatchsub said! If you ever decide to sell that puppy, make sure you give us first crack!
No, they were never sold in the U.S. I think they were commissioned by Subaru of AU and I'm never quick enough to snag them off of Nasioc when they pop up... Other things I would be interested in are: EA81 headlamp washer system with nozzles, water tank, button, relay, hardware, etc. and a set of tan EA81 wagon rear shoulder-belt harnesses, the three point style harnesses. I would happily pay for any/all of these parts!
I would be interested in several sets of the bugeye WRX headlamp protectors. The clear plastic ones that mount over the headlamps.
