Everything posted by Numbchux
95 Legacy EJ22 computer is cutting fuel pulses short while under heavy throttle opening
Numbchux replied to White95Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see a few interesting things. I'm not sure any of them definitively point to anything, but I'll post them.... Narrow band O2 signals can be difficult to read, but the fact that they both agree means it is probably not the sensors. The only thing those 2 have in common (other than the ECU itself, which I'm not ready to assume is the issue), is the main power wire. The O2 sensors, and the purge solenoid are the only things that get power from that side of the main relay. So a main relay issue (not unheard-of) could easily cause a drop in supply voltage to those 3 things, and nothing else. Easy enough to check.... More likely, though is that they are just reading the lean condition that is causing your hesitation. I think this is supported by the condition at 142 seconds, falling rpm and closed throttle means no fuel (I assume either between gears, or just coasting). I also see the fuel trims bumping into the positive. Which would lead me to believe that the computer is trying to enrich the mixtures to compensate for the lean condition. This completely contradicts what you're seeing with the injector pulses.... Assuming the TPS actually reflects movement of the pedal at the time, that looks normal. MAF looks unaffected.
4:44 LSD GL 10
'04-'08 FXT, '04-'05 Legacy GT, '04-'08 Outback XT, and 2013+ Crosstreks (That's just the application for the ring/pinion set, newest supersession is 38100AB681, MSRP is about $400, but you can find it for a lot less online, this will fit in any Subaru EJ 5MT, that's what I did)
Using a lift kit to make a frame/general chassis stiffening
It's really not, to do it the way the OP is talking about. Doing a "body" lift, and just connecting the lift blocks. It's almost perfectly a straight shot. And it certainly will do more than nothing. Probably won't bring it back to original strength, but will help a lot.
Transmission question about 3.7 and 3.9
Well....considering it's had an engine swap, the probably a rear diff swap.....who knows. There should be a transmission code on the bellhousing near the starter, google that and you'll have a good idea.
XT trip computer controller location?
I just swapped the radio on my XT6, and at least one of the plugs for the trip display plugs right into a silver module that's mounted to the tunnel under the radio. I assume that's it....
1996 body parts interchageable?
Numbchux replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, all the bodywork is the same. Windows in the rear doors are different between a sedan and wagon. But swap the glass, and everything else will line right up.
It would certainly help, whether it's as strong or not is completely debatable, but in my experience when these cars rust out, those suspension pickups fail first...so you're beefing those up considerably... I think it would be fairly crucial to extend not just from the strut/radius rod mounts, but up to the engine crossmember blocks, too.
Wiper adapter
I think AANCO makes one that fits the XTs (FYI, The XTs use a very unique spacing for those 2 screws). I made a neat Aluminum adapter once to use a RainX Latitude blade. But when I did, it never occurred to me to look into getting an OE blade. Now I know you can get the whole blade, with that bracket from Subaru (86542GA562), MSRP is $24.95, and you can order it online for less. I think I still have that adapter somewhere....I never even tried to look for it, I just put a new OE one on my '6 when I put it back in service this fall. And those screws are less than $2 ea. 86564GA050. That was nice not to have to deal with the old ones that had been in and out many times.
fwd 5 lug swap?
I assume FWD Impreza would likely have the shortest stock EJ strut, if it's any shorter than your average '90s non-Outback/forester one I did not notice a difference in ride height going from stock FWD '92 Legacy front struts in my XT6 going to '94 Turbo Legacy AWD GR2s. Slow day at work...so I did some digging. Rear hub/bearing assembly for a FWD EJ: https://www.rockauto.com/catalog/moreinfo.php?pk=219212&cc=1269806&jnid=665&jpid=7 Says bearing bore diameter of 1.1811" Rear bearings for a FWD XT6/EA82 are 30204 for the outer and 30206 for the inner National lists dimensions for those bearings, showing 0.7874" and 1.1811" respectively. (that's 20mm and 30mm) Now, since the EA bearings are 2 separate units, you'd have to have at least a measurement of the hub to get an idea of how the spindle length compares. But it might be possible to replace one of the inner races of a FWD EJ hub to match the smaller bore, or maybe even turn up a spacer... FWIW, EJ drums are all bigger than any EA one....so you'll still need to swap backing plates and such. Might as well go discs
fwd 5 lug swap?
I think it's possible. You don't have splines to deal with, and it's at least the same design (bearing pressed into the hub riding on a spindle, whereas the 4WD EJ/EA stuff is very different). The offset is probably pretty close, at least close enough to make up with a small spacer. Then the question really is just bearing diameter and spindle length. Both of which could be dealt with.... Also good news. FWD EJs use a hub separate from the brake drum, so it would be easy to put discs on it. If I had a FWD EA chassis, I'd try to get my hands on a used EJ FWD rear hub and give it a test-fit....
Ej22 swap, How did you lengthen your drive shaft?
Don't worry about it. It changed hands twice since I sold it, and the kid who did own/crash it was drunk driving at the time, so I don't feel bad for him. And the car was pretty well completely rotted out, so I don't really feel bad for it either. Wish I'd gotten some parts off it, but oh well.
IIRC, an EA82 shaft will fit, just have to make a mount for the carrier bearing. And, about 8 years ago, I had an EA81 wagon one-piece shaft lengthened for use in an EA82. 6" sounds right. Local driveshaft shop did it, but there was no warranty (they had to machine the flanges down a bit from metric to a standard tube size), Still no problems when the car was wrecked this last summer.
parts supplier woes.
I haven't found anywhere online that is as good when it comes time to warranty parts as any local place (not that NAPA is that great, I think AutoZone beats the pants off the rest for warranty). The fact of life with aftermarket parts, is a higher failure rate than OE, so you will be replacing them under warranty. You can buy the same part online for a lot less, but there's no, or very little, warranty support (you can probably get refunded for the part, but you have to pay up front for the replacement, and you'll probably be out shipping...). Look into US Auto Force. I don't know how nationwide they are, but we deal with them all the time for tires (we have almost the full gambit of local parts stores), and occasionally more, and they've been pretty good. I've looked a little at some of their parts availability, too, and it's pretty good, competitive prices, and good warranty coverage (again, we mostly deal with them for tires...). I've never called to order a part, but they have a good website using Nexpart for lookup (which is as reliable as anything...like RockAuto, sometimes entering year, make, model, engine gives you options that aren't available with that combination, but they do list dimensions and such so you can narrow it down yourself). With that said, we have an Amazon Prime account for the shop, and frequently order parts and supplies through them. The database is definitely not designed for auto parts, but you can look stuff up elsewhere, and then search for a part number.
- Getting my 2001 outback more adventure ready
Numbchux replied to White95Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, they have a MAF and MAP Like has been mentioned, that link is for OBD I cars, and yours is OBD II. Get your hands on a scan tool, just about everything on your list (and more) can probably be diagnosed by reading the live data on one. Something is telling the ECU to cut fuel. Plug in a code reader, go to the live data page, and look at TPS, MAF, MAP, and O2 signals, and see if they're doing anything strange. And yes, TPS is 5v
Numbchux replied to White95Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm fairly sure those have a MAP, mounted over on the RH strut tower. I know a '96 does, and while the '95 ECU is a unique animal, the rest of the management is pretty similar. With or without, a vacuum leak can cause problems (letting in air after the MAF = low reading at the MAF = less fuel). A '95 2.2 does have a fairly primitive OBDII, it would be worth hooking up a code reader and looking for stored codes, and watching live data of the TPS, MAF, and O2 while acting up. Probably way easier and more accurate than trying to read it with a scope. Also, a pre-O2 exhaust leak can throw the reading off....make sure the manifold gaskets aren't blown out, and all studs/nuts are present.
Ej swap into Brat, Clutch Cable, Which one?
Grain of salt....never done it with an EA81...but I had a couple thoughts I thought I'd share. If the issue is about travel, changing the cable won't help, that just gives you more adjustment range. If you need more travel, you need to change the leverage on one end or the other. I'm curious, a '98 [Legacy] Outback would be a hydraulic push-style case, easy enough to convert to cable, but requires moving the pivot ball and replacing the fork to change the leverage angle. Did you do that? Or was your donor an Outback Sport, in which case it would already have been cable? I thought that EA82 and EJ forks were interchangeable, but looks like they are not the same part number, so I could be wrong. But, even so, EJ transmissions definitely work in EA82 bodies, and EA82 trannies are swapped into EA81s all the time.....I would think it *should* be in the adjustment range of the stock cable.
Nick's 1987 RX
IIRC, Brad had a post about that with some history. That it was basically a completely optioned-out GL-10, and the only thing different between it and an RX is a few decals, and that it isn't white...
Swapping the 4.3Runner....IT RUNS!
Step one on that list has been wiring. When I did the engine swap, I did what I tell everyone never to do....and that is install it unfinished, and diagnose as I went. This had actually started causing issues (extra wires, poor routing, not sealed, etc.), and because of how tight behind the engine it was routed it was not possible to adequately clean up the wiring, and finalize the install. So, I pulled the intake manifold and distributor so I would have room to work, and pulled the GM harness completely back out. I've completely removed everything unused, I've shortened some of the wiring to clean up the install, I'll be using heat shrink fabric tubing to clean up the install and protect the wires. This way I can document exactly how it was done so a future owner doesn't have to reverse engineer what I did before being able to diagnose any issues. I also did have an auxiliary fuse panel for some of my extra circuits mounted to the kick panel near the passenger door. I believe do to it's proximity to the door, this panel got some moisture in it, and corroded really badly. So, I've got a much nicer Blue Sea fuse panel that I'll be mounting behind the glove box. In an effort to get better routing for the wiring, I decided I would drill a new hole for the wiring to pass through right behind the A/C evaporator, and since the rest of the A/C system has been deleted, I swapped out the evap box for the duct out of a truck that didn't have A/C (ebay for about $30...): This improves the amount of room behind the glove box immensely!! The fuse box will mount to the front side of it, and it leaves enough room above and behind it to mount the GM ECU safely.
Well, long time without update. Didn't do any wheeling in the 4.3Runner this summer. I got married in Alaska in June, we drove the 4.3Runner to our Reception barely into August here in MN which was really fun. There's a 1/8 mile drag race run on a public street right in the heart of town every year. I put the 4.3Runner in the car show with my buddy's Jeep on 35's. That was pretty fun, and the first time I had the topper off in a couple years. Over Labor day weekend, some good friends and I took a mountain biking trip to visit another friend near Breckenridge, Colorado. We spent 2 days riding downhill at Keystone, and then drove out to Moab to ride some cross country. Unfortunately, I took a nasty tumble early in the first day at Keystone, and broke my collar bone. While that took me out of riding for the rest of the trip, I still had a blast. First time in Moab. We did some dispersed camping for a couple nights. Our group was 2 Tacomas, a WJ Grand-Cherokee and a Ford Focus. The Focus got a little beat up getting to our first campsite. The second night, we set up camp closer to town, left the Focus and the bikes, and explored further out. It was a blast, some of the most fun I've ever had offroad. We made our way up along the side of a canyon, and watched the sun set from the top of the pass into the next canyon. This made me realize something. While I love the 4.3Runner, it would have been miserable on the road, and bored on the trail... I could tow it out, but then I'd be stuck setting up camp somewhere, and then making day trips. I'd really like to have more of an expedition rig, and while this rig could do it, I think I'd rather trade some sheer offroad capability for something with better street manners, more seats, more doors, Air-Conditioning, and towing capacity. Long story short, I've decided to sell the 4.3Runner, looking at likely getting a Sequoia. Maybe an FJ100 cruiser if I find a deal, but I think I'd rather have the space of the Sequoia than the aftermarket support of the cruiser. With that said, I've put together a plan of projects to wrap up some of the issues that have shown up, finish the projects I've started, and get it ready for a new owner. I'll document most of that here this winter, and hopefully be starting a new build thread next spring
Boosting a non turbo l wagon
Been done many times. Those ECUs are surprisingly quick to adjust fuel ratios for a little boost. You won't get any timing, though, so that's the big limit. We did it on my buddy's '95 impreza 3 times, the first 2 had issues due to supporting mods (Piggy backs....3rd time we let 'er buck on the stock tune, and it ran fantastically for about 30k miles). That 2.2 had well over 200k miles when we pulled it out for a WRX swap. I've seen several just push 7ish psi through them with almost zero other mods (hotter plugs, gapped a little tighter...). If I were to do it, I'd swap to parallel fuel rails, with pump and regulator for higher pressure. More fuel with the same setup, and better fuel atomization.
Lower gear or transfer case options
I wonder if anyone has used one of Bill's adapter bellhousings to a Toyota 4WD transmission. That might gain some clearance for a second diff without having to go so high. 4.444s are possible, and make for some pretty sweet gears, it's also pretty easy to swap to a higher 5th gear to compensate on the freeway. But, if you do lift it, it's probably not enough to compensate for larger tires.
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
Yea, if you're switching to 5x114.3, you'll likely be looking for different brake options, too (which you'll have a ton of options....might even be able to use 5x114 subaru stuff...). But, yea, I don't think there's a good way to have both patterns in the hub, as the 114 will require a larger OD of the hub, which won't fit in most 100 rotors. The end product would definitely be useful. SVX front suspension/brakes are very different than other Subarus, so probably not much help there, but there are plenty of other Subarus that are 5x114.3 and everything else is very similar (Tribeca, '05+ STi, '15+ Outback, '15+ WRX), it's definitely a MUUUUCH more common bolt pattern.
Swapping front drivetrain.
I've dropped the engine/trans/crossmembers as an assembly several times on Subarus. I usually take the suspension off, but if you can safely lift the car high enough, it would certainly be possible to leave it all together. With a hoist, it would be crazy easy.
