15
Everything posted by bratman18
It needs to be screwed in. Use a pair of needle nose pliers, or you may find a universal tool at the parts store. Just apply slight pressure and turn it clockwise.
EA71 fat case with FWD Impreza transmission
bratman18 replied to 1000 Pistes's topic in Historic Subaru Forum: 50's thru 70's
Yeah just get whatever ej transmission you want, and use an adapter Plate to attach it to your engine. You can get an adapter from a few different people on here. Check out the vendors for sale section. -
Yes they'll bolt on no problem. But if you go from phase 1 to phase 2, then you'll need the intake manifold to match the heads. Not sure on the power. I'm sure it would be barely noticeable if at all.
They're definitely a different bolt pattern. You could probably use an EA-EJ adapter plate like is done with the ej swap though. -
Just First Generation Subaru Photos!
bratman18 replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
Those are subaru 13" alloys. The brat is a 79 sitting on full ea81 suspension, with lift built in. Also with ea81 and 4 spd dual range. Needs some finishing, and a little fabricating, but it's VERY solid. Hopefully it'll be mine. -
My 1/2" Milwaukee takes off axles nuts like nothing. And pretty much anything else too. It has 475 lb ft of torque, and they now make one, the same size but different design, that has 1100 lb ft.
UEL single port headers (updated post)
bratman18 replied to sube101's topic in Products for your Subaru
I love the single port UEL header from you, even though the car still isn't finished. The only thing I'd change, is having the front pipe that wraps around the front, bend up more, so it doesn't hang down as low.- 39 replies
- fabrication
- subaru
(and 6 more)
Tagged with:
Jealous of those corner lights.
- 172 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
no tail/dash lights 85 GL wagon
bratman18 replied to Subruise's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had this problem once after I installed an aftermarket radio. I shorted something when I did it, and it blew a fuse. The tail lights and dash lights are on the same fuse. -
It's common on the ea81's to lift the front more than the rear due to the rake they have. I had a 2" front lift on my brat with just the torsion bar cranked in the rear. It sat nice with that.
There are plenty of places that get bad weather and cold temps that don't use salt or calcium chloride. They can use sand,and I know of areas over seas that use pea gravel. And they often sweep a good amount of it up after the winter and re use it. Yes, these can cause rock dings in the paint, and sand blasting, but that's far less damage than the others cause. And on top of that, it often is cold enough, that these products melt the ice, or keep it from freezing for a certain amount of time, and then because of the melted water, and cold temps, it actually freezes and makes it worse than it would have been initially.
It's the same here in Maine. Salt and calcium chloride kills cars quickly. And anything else it comes in contact with.
Nope, still not running right. I haven't had the time or ability to work on it for a while now. Hopefully when the weather warms up and the days get longer again.
