Everything posted by ocei77
Another torque converter came out thread, Seal? *PICS*
ocei77 replied to protivakid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you look into the tranny you will see the tabs that mate with the notches on the TC. Insert TC, lift an rotate. keep upward pressure as you rotate. It will catch. Keep rotating pushing inwards. It will jump @ two more times. It is fully seated when the outside mounting tabs are about 3/8 of an inch from the tranny block looking from above Before mounting the engine. Give it a few insurance turns to make sure it is fully seated. O.
Drive shaft interchange
ocei77 replied to cookster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck opposedforces.com. Get your car and part then afterclicking on the part number you will see usage info. Will list cars that interchange. Could also check car-part.com. It may list it also. O.
Mystery Problem
ocei77 replied to wescolvin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only time this happened to me (not with a Subaru), was indeed related to heat. The solenoid was getting heat soaked and would not work until it cooled. I put a wet rag on it to help cool it and immediate start.. Worth a try.. Replace the contacts and plunger(($10-15 on E Bay) rather than buy a complete starter. O.
2002 Legacy Timing Belt job SOHC cam sprocket alignment help!
ocei77 replied to 1986Brat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1^ Note the cam and crank marks. The belt marks will not line up again. O.
99 OBW, best place to "break down"
ocei77 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, that is what happened to my steel terminal. Seemed like the battery post was too small in diameter. Tighten the clamp as much as I could some time ago, but ran out of room to tighten any further. Clamp had not been real tight for some time. Common issue with oem cables and third party batteries. I have used a length of solid copper wire, breaking it off after tightening and the prong from an appliance plug to fill in the gap. O.
brake light on and will not go out
ocei77 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter running a while does the light go out? If so, it's related to condensation in the brake booster hose. In this case remove hose and spray with brake cleaner. O.
Frozen nuts/bolts, remedies?
ocei77 replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst you don't need to remove the strut bolts to do an axle. Turn axle so the bevel side faces you. Punch the pin out. Don't turn the wheel. 3/16 punch. 32mm for the axle nut. Good breaker bar (forget the harbor freight one for this), plus a cheater pipe.(that axle nut is REALLY on there) Remove the sway bar bolt. Remove cotter pin from lower ball joint and unscrew the castle nut (19mm). Pry the control arm down( you're not trying to remove the ball joint, so don't remove the bolt that secures it). Now you can swing the hub assembly out. Just pull and it will come out of the tranny and tap the axle side out. New axle bevel has to face the same way. Roll pin into bevel side. Axle side in. If the roll pin won't go all the way through ,the splines are off 180 deg. The control arm up, it will stay in place. Tighten all nuts. Torque the axle nut (@140 ft lbs) then stake it. Before removing the strut bolts at any time (especially the upper) use a chisel to mark the nut and the bolt, this way they can go back the way they came out, saving you a realignment. If no impact gun, a 19mm to hold one side while you wrench on the other. 6 pt sockets and 1/2" drive are best. You need a penetrant of some type. The fsm is available in the sticky above, 2nd page under my name. O.
Ej25d Weird Timing Belt Tensioner
ocei77 replied to jread's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use a c clamp and compress til I feel a lot of resistance, hang it vertically and do someting else and repeat til done. Have never had an issue. O.
2001 outback engine
ocei77 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOOps! O.
ocei77 replied to jread's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe old style two piece which many of us prefer (the hydraulic part seldom goes bad). Why?, less mfg cost. O
EGR code
ocei77 replied to sub96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are other tests to be made. Google Subaru DTC codes and check yours. Make sure the small metal line from the EGR to the solenoid valve is clear also. You can test the solenoid by connecting the green plugs under the dash and turning switch on. Listen for the clicking to confirm operation. Don't forget to unplug afterwards. In the future please start with more specifics.ie Engine, mileage. O.
Is the naturally aspirated Impreza/Forester radiator compatible with Outback
ocei77 replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year OB? seems like the recovery and cap fitting are on the wrong side. You can always run extra line for the tranny cooler. O.
Changing front O2 sensor 03 Forester
ocei77 replied to brighton98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjack it up and remove the heat shield bolts (you'll probably have to cut them off). This way you can raise the shield enough to get an open end onto the bung and another on the sensor itself. If you don't a good 19mm open end, a small pipe wrench will work also. Spray with PB and try to tighten a bit to break the tension. Then unloosen. O.
idle problems
ocei77 replied to sethisaac's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany codes? Sounds like the IAC. Any coolant issues? O.
Changed water pump/timing belt now car wont start
ocei77 replied to khalimatical's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have the marks correct. Is the tooth count on the belt correct? 44 from crank mark to passenger cam and 40.5 to driver cam. If this is correct then something is unplugged. Check crank , cam sensors and IAC hose to intake. O.
95 Legacy EJ22 computer is cutting fuel pulses short while under heavy throttle opening
ocei77 replied to White95Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse emery boards to clean the contacts. Unfortunately I left my diagram of pins for the harness where I won't get back to for a few days. In either case looking at the back of the connector #1 is Br, 2 is LG, 3 is LR and 4 is YL. Check resistance and see if one/more are much higher than the others. This may help you to narrow down if only one or two pulsing low. O.
4eat trans swap
ocei77 replied to themixtoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTho this issue is resolved. In times like these,I try to get a pipe wrench on it. If there's only enough room to make an 1/8 of a turn its generally enough to break it free. O.
ARP Head studs in a non-turbo EJ25 engine
ocei77 replied to ebbsspeed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou buy the ones that fit the engine. SOHC or DOHC. But these are for people who run big hp. Why spend over $100 on head bolts that don't need to be replaced on a run of the mill engine? O.
Need help with axle change
ocei77 replied to Wallis_93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe roll pin should go in from the beveled side. If the pin doesn't go all the way in, the splines are 180 out. Watch the orientation when you do the rear. Install in the same way it came out. O.
DIY clutch cancelation switch
ocei77 replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only problem is eventually you'll forget to take it out of gear, reach in and whoa! O.
98 Outback Checking engine and dumped oil. 2.5l to 2.2l swap ?
ocei77 replied to legacy93wagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLarge screwdriver from behind. Can even tap with a piece of wood against the sprocket, rotating to even the movement. O.
ocei77 replied to legacy93wagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe chips on the pulleys are benign, If they are not cracked I wouldn't replace. If you want to, a junk yard would be your best option. I've never had to use a puller to get them off. You are replacing the idlers, right? Remove oil pump and tighten screws on back if loose. Don't tighten the valve covers until after you have tightened your sprockets. A 1" open end will fit the flats on the cams to hold them. Careful of torque on cam bolts, the specs are very light. I know where the plug goes, but not enough knowledge to tell you where it goes w/o looking at an engine. Am sure someone will chime in here. Continue to take your time and all will be well. O.
How to turn off car alarm?
ocei77 replied to ryanw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe button may be pushed up some. It is by your left knee area. Get a flashlight and look. Once found, push in while cranking. This will hold until the next time the battery loses power.. Replace the battery in the key fob and go to cars101.com and look under programming remotes. O.
The 1997 Subaru Legacy Wagon Progect
ocei77 replied to thestudent's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need HG. All depends on what you can do mechanically and your budget. If a 2.2 swap is reasonable then that would be a great option. or fix the HG with Subaru turbo gaskets, Six Star, Cometic and lastly Fel-Pro. The heads must be resurfaced, which you can do yourself. O.
ocei77 replied to thestudent's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClassic HG issues, Engine? Mileage. When full do you get heat? How long does it take to oveheat? Doesn't o/h at idle, but after driving a bit, the gauge goes to hot? O.
