Everything posted by bratman18
Struts comparison height and tire Clearence
03-08 Forester, and 96-99 Outback give the most, and are about the same. It's the rear spring perch that causes the most restrictions, but both of those have higher rear spring perches than the 98-02 Forester rear struts.
1994 suby loyale, bigger tires/wheels?
http://www.ultimatesubaru.org/forum/topic/110178-offrood-faq/
$2000+ repair worth it for 1998 Forester? HELP!
bratman18 replied to annielumc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsually takes more time doing it in the driveway. But in a garage, with a lift and all the tools at your disposal, it doesn't take long at all. Especially when you do that kind of work everyday.
bratman18 replied to annielumc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$500 is still wayyy too much. A new axle is $100 or less, and the knock sensor can be had for $20 off ebay, but even $100 or less from a parts store. The axle takes 20 minutes to install and the knock sensor take 10-15. So you were charged $300 for less than an hour labor, plus parts mark up.
The Unofficial "How to Lift your Impreza" Thread
They'll look a little small, but not too bad. And it'll look about the same whether you use forester strut assemblies or Outback strut assemblies. They both give about the same lift. And no prob.
Forester and Outback struts give about the same amount of lift. And that 2" rough lift estimate, is the full forester strut assemblies with springs. You're looking at 2-2.5" of lift using forester or outback strut assemblies.
bratman18 replied to annielumc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are raping their customers with prices pike that. That is insane. Even if you buy an oem knock sensor, it's only around $100, and about 5 minutes to install. Same goes for the rest. Take it elsewhere. Or do the work yourself.
As you said, Forester struts will be a direct bolt in. And it's 96-99 Outback struts that would be as well. Use the springs that go with the struts for best results. And you don't NEED the trailing arm brackets or the sway bar brackets, but it doesn't hurt to have them. I've never used them. I removed my rear sway bar all together. But if your just going for the look, and don't care about offroad suspension travel, then a sway bar wouldn't hurt.
PII EJ25 shortblock/PII EJ22 heads frankenmotor
Everything I've seen and read says the phase 2 2.5 heads and the phase 2 2.2 heads are basically the same.
Yes. 02-07 IMPREZA are easier. You can just bolt outback or forester struts right in. No need to drill or change out rear top hats. Just bolt the new strut assemblies right in
Head Trauma, inc. Bumpers, Racks, Guards
Can you post more pics of the EA82 front bumper you have on your site?
Yeah it has decent rumble. Nope, it's been in Maine since new I believe. And i added the rear wing and everything. And the exhaust was actually rust free and mint as well!
Thank you! Got lucky to find this in my area, and it was terrible to start with, but rust free. The exhaust is custom. It has an ej22 swap and it has an inferno fab header, and then custom the rest of the way back, and goes up over the rear crossmember tube, and into a cherry bomb muffler, then has a 96 Outback exhaust tip.
My new turd, Lifted 90 Turbo 4WD
Those are Peugeot wheels.
- 98 lob jdm swap questions
bratman18 replied to shoebee2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEither the exhaust is aftermarket, or its a turbo motor.- My '83 GL Coupe - Hardtop SSS
- 1984 GL Wagon Fwd Build
Nice man. So jealous of the garage, and house for that matter haha. Congrats on moving in!- Just First Generation Subaru Photos!
- The Awesome Older Generation Picture Thread
Scangauge 2 installed in my ej swapped Loyale. Makes it nice to know the exact coolant temp.- 1998 Legacy Wagon - best options for lifting?
bratman18 replied to barneyb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX98-08 forester strut assemblies, or 96-99 outback struts. Trailing arm is the same between both. It's the trailing arm bracket that's different, and isn't absolutely necessary when lifting a Legacy.- Franken Subaru
Ya know, none of us have a problem with the car. The car is cool. I love lifted OBS's. But when you come on here acting like what you have is some big secret, and not wanting to share info about your ride, it comes off pretty rude and uninviting. It's not a 10.5" lift. If you have 6.5" spacers on top of forester struts, then again, it's not different than what any of the other guys have done to theirs. Forester struts do not give you 4" of lift. Maybe 2.5" at the most. And you don't count tire size as part of the lift either, now maybe if you had said initially that you have 10.5" of clearance, it would have been ok. It's an awesome car, but you didn't re-create the wheel. Improve your attitude and you'd have a better response.- Greetings from Maine
Welcome, I'm in Jefferson. Be sure to check out the local Maine subaru forum as well. Mainelysubarus.com- 5MT wont fit
bratman18 replied to Aluxes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^don't even need a masonry bit, it's aluminum! - 98 lob jdm swap questions
