Forgot the Lifters
Hydraulic lifter cams will usually have a higher profile/larger lobes for lift. Usually. I’ve heard that machine shops prefer hydraulic lifter cams when grinding new profiles for a solid lifter engine because there’s plenty of meat to use for the change of opening angles, duration and height. Cheers Bennie
EA81 Brat Wheeltrack Widths?
FSM = factory service manual. Cheers Bennie
07 forester xt
You guys get smog still? That’s crazy! I remember the smog induced ozone over Melbourne in the 90’s - we would see the brown dome over the city as we approached from our rural setting. We would always come home with headaches after a visit to the big smoke. Now that’s a very rare event, if it happens at all these days. Thats so good with the experience you’ve had with GD and his crew. From an outside perspective and not ever having done business with GD (never will due to locations), it was awesome to read about the communication from GD’s workshop and yourself through what you shared with us on here. Very positive!! Have a safe drive, lay off the smokes (it’s bushfire season!) and enjoy the ride! Cheers Bennie
Car Alarms For Old Subes?
The stealing for OS doesn’t really happen here. It used to happen for interstate sales, but with the state authorities finally getting their act together and sharing info, this is a lot harder to do now. Chop shops are sort of a thing of the past really, but organised gangs are known to buy a legit car and plan to steal one of the same make/model etc and do a driveline/interior/accessories swap. Then cut the stolen body up and dump it (probably recycle it these days), after all that sell the legit car for a much higher price and a tidy profit. This happens very quickly once the target is stolen. Cheers Bennie
Is there ever such a thing as this?? I think not. Just scum. Cheers Bennie
2008 2.5 engine in a 2011 2.5 ????
el_freddo replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can’t work out how that valve master system works - is there another piece require to fit one of those tools into? I’ll keep it simple at my end - I’ve used this a number of times successfully: https://www.amazon.com/GEARWRENCH-2078D-Universal-Overhead-Compressor/dp/B0002STSGC#immersive-view_1575671478784 pretty easy to use on EJ251 heads, it’d be a different story on DOHC heads I reckon. I didn’t get mine from Amazon, I got it from a local store. Cheers Bennie
el_freddo replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShort block = block only. Long block = block and heads, nothing else. What GD is saying is that you need to take the 2011 heads and fit them to the 2008 block. Job done. Cheers Bennie
99 imprea 2.2 doesn't have injector pulse
el_freddo replied to poorboy87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwesome! I’m surprised you didn’t notice the difference in the cam sprockets - an easily noticeable difference without removing the timing kit. As of why one has seven and the other only two, it’s related to the changes in the crank pulley tab count and how the ECU references both of these for ignition and injector pulse timings. Cheers Bennie
Yes they do. So not only do they get done for car theft, they also get done for arson IF they’re ever caught, more not caught or linked to the arson than those convicted. A burnt out stolen car of mine is probably my worst fear for my Subaru’s Cheers Bennie
07 forester xt
That’s insane. Settle down Maverick! Cheers Bennie
el_freddo replied to poorboy87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDouble post
el_freddo replied to poorboy87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX@poorboy87 it’s not ignorance, it’s learning I only know of the cam and crank changes because it effected a mate of mine that basically did the same thing you’re doing... Cheers Bennie
Hitachi Carburetor alternatives
I got an EJ22 and NEVER looked back. What a night and day difference!! Plus the EJ is uber reliable! Cheers Bennie
- BRZ Radiator for ej swap
Dipstick broken off in tranny
Through the dip stick hole or the drain plug? Magent on a rope could work if it’s the right size to fit in the drain hole or the dipstick tube. Got a pic of what’s left of the dip stick? Cheers Bennie
07 forester xt
AE, are you sleeping at night? I wouldn’t be due to pure anticipation! Cheers Bennie
el_freddo replied to poorboy87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure? Did you physically check the back of the cam wheel and compare the tabs to ensure they’re the same? The crank pulley can be done by eye without removing the cam belt or pulley. It’s got to be something simple that’s being overlooked like the cam wheel. Cheers Bennie
https://dynamco.com.au/product/446002-autowatch-alarm/ I’ll be installing one of these in the near future. Main problem with any decent alarm system is that they’re typically costly! Plenty of add ons depending on your needs. Cheers Bennie
FJ1600 Question
That’s a bugger about the flywheel bolts! Sounds like you got on it at just the right time - when those bolts let go all kinds of hell breaks out! A mate of mine who’s into track racing has a small section of pipe that’s hammered around the outside of all the bolts and tack welded. This ensures the bolts can’t ever move. If you need to remove these bolts, simply grind off the tack welds and off you go. When’s the next race occurring? Cheers Bennie
Save This Subaru!
I’d take that on in a heart beat if it were close enough to me over here! We know of only three in Australia! Cheers Bennie
Talkeetna; the offroad 5 lug 85 wagon.
Nice one Akg! I’ll be looking forward to some pics of the wagon. The 5 stud pattern has little to do with the lift other than the strut length in the front end. About ten years ago it was quite a common conversion on lifted L’s over here in Oz when crossbred performance were building bolt on kits for the 5 stud and bigger brake swap. Sounds like it’ll be a sweet setup once you’re done. Will you go for an EJ22 swap too? Cheers Bennie
Legacy II 2.2i, (BD) sedan, 1997
If you wanted to keep the sedan you could replace the rear suspension on that corner. Then it’ll just be cosmetic from there. Cheers Bennie
That sucks mate! Just about everything will be interchangable between the two vehicles, other than rear panels etc. With the rear struts I think there is a difference with these but I think it’s the top hat and spring rate. You’ll love the wagon! Glad you were ok. Not fun, but everyone is safe, that’s the main thing. Cheers Bennie
Help diagnosing manual transmission problem? 2000 Legacy GT
el_freddo replied to consmi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI’d say it’s the bearing between 4th and 5th on the upper shaft. Probably caused by low oil. It’d be cool to pull the box and get some pics of it’s internals. Cheers Bennie
Save This Subaru!
MY hatch, and if the pics are accurate, a very good looking one too. Cheers Bennie
