5
Everything posted by Scott in Bellingham
Help me before It drive it off a cliff
Scott in Bellingham replied to Gasket97's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can help next week, I'm booked up this week -
what size tire for 2'' lift?
Scott in Bellingham replied to Ashwell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you can redrill the 6 bolt rims to 4 bolt or redrill the hubs to 6 bolt Ive done both with good results, either way you use 2 of the original holes, I can do your hubs at my shop , 26" on the 2" lift -
90 loyale 2'' lift
. Comes with the 1" blocks ! They are 1" aluminum -
Ej22 swap wiring help
Scott in Bellingham replied to Tye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hooks to wire on the starter, has power only in start mode,disregard trans wires -
Would a lift kit devalue a Brat
Scott in Bellingham replied to iluvdrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can lift a car and later remove the lift, just don't cut the body anywhere -
Will these tires and wheels fit?
Scott in Bellingham replied to MR_Loyale's topic in Subaru Retrofitting
Too big for a 2" lift find some 27" tires -
The ground is threw the engine harness, yes you need the brown main relay powered with ignition key -
The SJR lift block has the letters facing to front, I guess it is because is a 4" Lift? On my "BumbleBeast" the SJR letters are towards outside of the Fender... Style has changed over the years your both correct
The 96-99 OB struts for the rear will work , after 2000 they are coil over shocks, will not work for the older cars
On the passenger right side on the intake I replaced the pulley with a exhaust pulley but I know the markings wrong, if I had a look at a proper intake pulley or knew were the cam alingment pin position was I could time this thing, the car had been in a wreck so the correct pulleys gone, anyone have a picture for me ?
just me and pat went out, great day wheelin, https://www.facebook.com/photo.php?fbid=1859299780962248&l=ab4601bdf4 https://www.facebook.com/photo.php?fbid=1859300170962209&l=18ffbc4e94
Cars ready see ya at the orv park
