# Water pump
Ordered an EJ251/253 short block, 255 pistons inside?
- 3 comments
- 1692 views
EA82 water pump pulley alternative?
- 4 comments
- 1417 views
New to Subaru - Down Under with a 1986 Vortex XT
- 11 comments
- 4200 views
99 Legacy Outback - Still overheating and no heat after timing belt and water pump replacement...
Cooling System not working properly - Tried everything.
- thermostat
- sensor
- sender
- cooling
Tagged with:
- 42 comments
- 7837 views
Water Bypass "Rubber" hose Install
- 5 comments
- 1789 views
New water pump leaking...
- 11 comments
- 2945 views
88 GL Water Pump Replacement Questions...
YnotDIY ·
- water pump
- sizing
- aftermarket
- 88 GL
Tagged with:
- 10 comments
- 2301 views
Broken water pump bolt ... how bad can it be?
- 12 comments
- 3669 views
No coolant pressure? Overheats with AC running.
beamsbox ·
- Pump
- water pump
- pressure
- coolant pressure
Tagged with:
- 13 comments
- 2280 views
1985 GL Wagon Water Pump Change
dewloft ·
- 10 comments
- 4094 views
Changed water pump/timing belt now car wont start
after market timing belt and water pump
- 7 comments
- 2199 views
95 Legacy L timing belt job.
- 74 comments
- 9431 views
SOS-Please Help Me, for the love of God!
- 13 comments
- 3655 views
Water Pump 89 GL O-Ring question
- 5 comments
- 1615 views
Outback problems
JDanco81 ·
- 4 comments
- 1688 views
EJ25D 2.5 DOHC - Advice for timing belt kit w/ water pump, idlers, tensioner
kevinrse ·
- EJ25
- EJ25D
- timing
- water pump
Tagged with:
- 4 comments
- 2721 views
1996 Legacy LS Sedan, purchased, repaired, still overheating
- 22 comments
- 2591 views
92 Loyale Wgn EA82 Coolant Loss Problem
- 16 comments
- 4993 views
