153
Is subaruxt.com gone?
el_freddo replied to Masterofreach's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That sucks when it happens. They should pass on the torch to those that will keep it alive. Cheers Bennie -
@Mitchy - there is a bit of effort involved with a swap like this. But it’s nothing compared to a dashboard swap or removal of an EJ dashboard - a common occurrence went people “drop” and EJ turbo into their non turbo Subaru. This is my second dash install and my fifth removal in the MY platform. It’s very similar to the L series dash removal and install process, as I’m sure it is for the EJ dashboard. I’ve worked out the indicator issue - it was the plug to the indicator stalk cluster. The plug on my indicator wiring had one pin that’s been hot enough to melt the plastic of the plug, changing the pin’s position slightly. With a small tweak with a pair of pliers I was able to seat the plug properly with its mate and I had indicators again. I also located the plug for the intermittent wiper relay canister to live on. It was tucked right up behind the instrument cluster. For now I’ll place the single looped wire plug on there so my wipers will at least self return. Then I’ll go hunting for my intermittent relay canister to fit for my wipers to work with the four position switch - off, intermittent, low, high. Such high level of luxury! The windscreen was fitted yesterday. So now I can focus on getting the rest of the interior back together and sort out the rust in the tray - clean it up and seal the metal. Cheers Bennie
- 21 replies
- BRAT
- Brumby EA81
(and 1 more)
Tagged with:
Mitchy, are you aiming for more lift than this, or are you happy with that height? In the before and after pics it’s difficult to see the difference, it looks like it’s maybe an inch or two at best. The lighting unfortunately makes it hard. I do like how you’ve positioned the car on the same angle though! Cheers Bennie
84 Brat Transmission rebuild...stuck!
el_freddo replied to Britfire's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That 4wd transfer case won’t come off until you remove the gear on the back of the pinion shaft for the 4wd action. It’s a bloody stupid design with the pinions haft fitting through a hole only big enough for the pinion shaft. Once this gear is off, the 4wd transfer housing can be removed, then the four retainer bolts in the pinion shaft bearing housing can be removed. After the case half bolts are removed the cases should split apart with some persuasion from a rubber mallet. And I don’t recall any reverse lockout device or 10mm headed bolt on the selector fork in the 4spd box, only the 5 and phase1 EJ boxes. 4spd box = nothing like the 5spd box until you’re at the 4th gear and forwards from there. Even then the concept of the low range is the same but the layout is different. Cheers Bennie -
And if you’re pulling the interior from another vehicle you’ll have everything you need for this conversion/swap. Wiring will be under the carpet of the donor, if not in your vehicle, you’ll probably find that the under carpet wiring will plug in under the dashboard somewhere on your vehicle. Cheers Bennie
http://offroadingsubarus.com/macpherson-strut-to-top-wishbone-conversion/ here’s the link to the strut delete I was talking about ages ago - used strictly for racing and jumping HIGH! Strut and spring swap would be so much easier! Even if you built your own spring compressor like what’s shown in the video posted earlier. If you got separate strut and spring orders in, your probably have it all put together by now! Cheers Bennie
Go easy on the throttle - drive like a a grandpa and you’ll extend the life of the 4speed Cheers Bennie
Awesome! I loved my L series in the snow! What I found was the engine would run hot because the radiator was cooling the coolant too low/quickly. A piece of cardboard over half of the radiator had temps sitting where they should. Only difference there is that I’m running an EJ22 - where the thermostat is on the cold inlet side of the engine! Your EA82 will have the thermostat on the hot side so it shouldn’t be effected in the same manner - unless you’re getting a frozen radiator (I’ve seen that happen before in very frosty conditions if you don’t warm the whole cooling system up properly). Other thing to investigate is the possibility of a leaking heat gasket. And do you have true AWD or part time 4wd? The true AWD box has a vacuum operated diff lock solenoid and if it hasn’t been toyed with, it comes with a poor low range of 1.19:1 - good for rallying in low range! If you’ve got the part time 4wd box and a non turbo, you’ll have the good 1.59:1 I really miss driving in the snow! Cheers Bennie
The RXII coupe and the Vortex (XT4) and the XT6 are the sources for these gearboxes. The low range is on the gearbox input shaft, it sits above the front diff before any power goes through to the drive gears. There is no swapping of stub axles or ring gears wth this swap. The ring and pinion swap is for a diff ratio change. By dodgy I meant that it’s a low range that’s not very low. It’s a 20% reduction vs a 60% reduction for the good low range. They’re just ratio changes. Cheers Bennie
1984 GL Wagon 4WD Fuel Pump Problems
el_freddo replied to markjs_pnw's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If a blocked fuel line - remove filler cap and blow compressed air back into the tank through the fuel outlet line. If this clears the line, pull tank out and give it a good flush. Cheers Bennie -
You’re reading about the EJ 5spd box and you’re pulling apart the 4spd unit. They’re different gearboxes! What you’re dealing with there is the part time 4wd engagement system. You need to pull it apart - and remove the rear output housing to achieve this. I’ve pulled one of these apart. It’s not fun - and I don’t have to get mine back together! There’s a process you need to follow to get all of that out properly. You will need to remove all the cotter pins holding bits to shafts etc. Just that I don’t know what this process is exactly. THEN: wait until you get to the pinion shaft - you need to undo the bolt on the end of the pinion shaft. I believe it’s a 34mm bolt. And it’s an offset hole to slot your socket through. That didn’t work for me. The angle grinder did though as this box is junk and I wanted the front diff stubs. Best of luck with it, I’m sure it can be done - you’re at the difficult part atm. Hopefully someone can give you the instructions on how to do it properly! Cheers Bennie -
If you have a part time 4wd box it will bolt straight in. You will need MPFI or MPFI turbo front driveshafts as the diff stubs are the larger 25 spline units. Also grab the instrument cluster if it’s available. And the vacuum solenoids that operate the diff lock You will have the dodgy low range in this box (1.19:1 vs 1.59:1) compared to the PT4wd L series box. They’re a drop in interchange job if you want the good low range. Worth the effort! Cheers Bennie
Some ideas for the future?
el_freddo replied to ClassySoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes. Your EJ will bolt to any EJ series gearbox, including the 8 bolt boxes (phase 2 - just use the four bolts that your engine has). Cheers Bennie- 19 replies
- 1
- lift
- transmission
(and 1 more)
Tagged with:
Dashboard is in. I had a few little issues putting it in, namely around the air vent ducting clicking in properly. But for the most part it’s in and almost everything works. It looks good and I can’t wait to go for a drive. Much better to look at than the original speed, oil/fuel gauges and a clock that didn’t work - I set it to 5 o’clock I’m not sold on the green backlighting, time will tell about what happens here. After finalising this install I need to fit an alternator and an air filter, pay rego that’s overdue, then go for a long overdue drive! Cheers Bennie
- 21 replies
- BRAT
- Brumby EA81
(and 1 more)
Tagged with:
There will most likely be a black box in the drivers kick panel area, six plug from memory. These can become faulty. Although I’ve not personally experienced this. One way to tell if you have this box or not - when you turn the ignition on, does the pump usually run for a few seconds then turn off, OR does it run all the time? If it runs all the time you do not have this box. If it shuts off, you’ve got this box. Also ensure your fuel filters and lines are not blocked. Cheers Bennie -
Depends on what you put in. The EA AWD box will bolt straight in but will need MPFI shafts for the larger diff stub output shafts. EJ box will need custom crossmember, tailshaft, possibly gear selector linkages and matching rear diff ratio of swapping ratios. And you’ll need the MPFI drive shaft for the larger diff stub output shaft. When you say “go up the mountains” - does this mean offroad or on the black top through the twisties? Cheers Bennie- 19 replies
- lift
- transmission
(and 1 more)
Tagged with:
Shame you have to move this on. Such a unique car! Cheers Bennie
Correct. Trans swap is involved either way you go. Cheers Bennie- 19 replies
- lift
- transmission
(and 1 more)
Tagged with:
You guys are kind of stuck in America if you like the dual range. With those wheels you should be alright to pull that speed. For a period of time it probably won’t be fun. You could drop in the RXII AWD dual range box, swap the low range to the good L series version, swap the diff output stubs while you’re there too. Fourth ratio can’t be swapped without swapping 3rd as well. One side of the gearing (I can’t remember off the top of my head if it’s the top or bottom set) are cast/“stuck” together. 5th gear is a Lone Ranger and can be swapped independently - and the EJ phase 1 5th ratios are a direct swap. In the RX box you might find those ratios a bit more user friendly for what you want. These ratios are “wide” as opposed to the NA set that are “close”. The AWD box has the same internals as the EJ internals with the exception to the dual range - which makes single and dual range internals NOT interchangeable. I’ve got the RXII AWD box behind my EJ22, 4.111:1 diff ratio (not an easy swap but possible with a machinist!), turning 27 inch diametre tyres, matched speedo. I put in a different 5th ratio that turned out to be too short (same as what you’re running now - 0.87:1 - I wanted 0.78 from memory, the box I think came with 0.73:1 - which I should’ve just tried in the first place.). So you’ve got some options, but they’re limited if you’re married to the dual range. If dual range doesn’t matter, you’ve got loads of options from the EJ box series. Cheers Bennie- 19 replies
- lift
- transmission
(and 1 more)
Tagged with:
This is happening Stock brumby dash up top. This is the ONLY factory available dashboard and instrument cluster for the brumby in Australia. The lower dashboard and six gauge analogue cluster is from some touring wagons (most are digital), Coupés and the GL sedan. And of course it’s all Lego So this will be in soon. EJ wiring loom is being laid out for future use too Cheers Bennie
- 21 replies
- 1
- BRAT
- Brumby EA81
(and 1 more)
Tagged with:
Yep, same boot, almost the same issue as what you have there. A few more months (maybe) and it would’ve gone the same way as yours. The other three boots up front are fine - because they’re not located near the exhaust! I’m lookig at making a heat shield for the boot to help increase its life expectancy. I hope that repaired shaft does the job for you Cheers Bennie
There’s a permanent power wire, then there’s an ignition “ON” wire. You now need to find and check that ignition wire. Some of the SPFI conversion documents could provide you with the ECU pinouts to help find the ignition wire. I can’t remember if the SPFI ECU has one, but the ignition relay could be dead too. Worth looking into anyway. Cheers Bennie
